post processor not processing
Hey all, I'm having trouble with a cut-file on command cnc, when I ran the post processor in sheetcam it said there was an error, but after a couple tries it went through, but it didn't do the peck-pierces that it was supposed to, here is the ngc, wonder if someone can tell me what I'm doing wrong in sheetcam.
Re: post processor not processing
here is the ngc file
- Attachments
- slides for manure spreader.zip
- (425 Bytes) Downloaded 97 times
- WyoGreen
Here is what was in the file.
(Filename: slides for manure spreader .ngc)
(Post processor: CandCNCPlasmaLLCNC-rev26.scpost)
(Date: 01/21/2019)
G20 (Units: Inches)
F10.0
G90 G40
G64 P0.010 Q0.001 (tracking tolerances set to 0.01)
M68 E0 Q10
(Part: pusher-front for manure spreader)
(Operation: Drill, 0, T2: 85 amp 3/16 steel, 0.0156 inch Deep)
M68 E0 Q900 (Global DTHC ON/OFF is ON )
G4 P.1
There is nothing in there to do any cutting. There have been several posts over on the Sheetcam forum by people having similar problems. If I remember right, there was a corrupted license file causing the trouble. You might do a search over there.
(Date: 01/21/2019)
G20 (Units: Inches)
F10.0
G90 G40
M68 E0 Q10
G4 P.1
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
I will look over there then, thanks.
