Remote Control for Any Plasma Table
Topics related to pen markers, remote controls, drawing tablets, & other plasma table related accessories
Granite
Post by Granite »
This is the best $20 upgrade I've ever made. Just plug in the USB dongle and it auto installs. I keep it in a zipper bag when using it, about the only clean item near my table. :lol: (Power switch is still easy to access when its in the bag)
Found it on Amazon. Been using it for a few months now. (Also works great on my Smart TV) Scroll to bottom for video.
Here is a short video demo. https://youtu.be/fVMtoplbjss
Re: Remote Control for Any Plasma Table
tylerd
Post by tylerd »
Does it work with Command CNC on linux system?
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
C&CNC Bladerunner Servo
DTHC IV Feather Touch
HyT-Connect DCP-01
Sheetcam Inkscape QCAD
Granite
Post by Granite »
tylerd wrote: Thu Mar 28, 2019 2:14 am Does it work with Command CNC on linux system?
I know it works with Ubuntu (a free OS running on the Linux kernal).
Thor
Post by Thor »
I have same one on my command cnc, works well. Need to figure out more keyboard shortcuts to do things like change from continuous jog to step and a few other things would be nice. I mostly just use mine for finding corner of sheet.
Jason@bc
Post by Jason@bc »
I don't have wifi in my shop, will this still work?
Granite
Post by Granite »
Yes, it has a dongle that plugs directly into your CNC computer USB port.
Granite
Post by Granite »
Granite wrote: Thu Jun 20, 2019 2:36 pm Yes, it has a dongle that plugs directly into your CNC computer USB port.
The keyboard communicates directly with the dongle, WIFI is not necessary.
Jason@bc
Post by Jason@bc »
Thanks a lot for the info, Granite.
Jason@bc
Post by Jason@bc »
I can't make mine work, it does toggle different tabs on the screen but no movement on the table at all?
Granite
Post by Granite »
Does your CNC use a Windows or Linux computer with a standard keyboard? If so, you should be able to perform all functions with your remote keyboard, the same way you are using your primary keyboard. In fact they work simultaneously.
Open Notepad or some other application outside of your CNC controller and type a word to confirm your remote keyboard is functioning. Keep your primary keyboard plugged in. You should be able to use both at the same time. Type a few lines of text then use your arrow keys to navigate your cursor.
scubadog
Post by scubadog »
This isn't wireless but it works great on a Mach 3 system
https://www.ebay.com/itm/4-Axis-USB-Pen ... 2749.l2648
Jason@bc
Post by Jason@bc »
I can type in numbers and stuff on notepad, but still no movement whatsoever on the table, there's nothing to change on the settings etc?
try clicking on the NumLock key once (on your normal keyboard) then try the keypad
there is a guy who has a video out showing how to synchronize a remote keypad to transfer command keys to the remote.
https://www.youtube.com/watch?v=F1Siihp0nSo&t=890s
Jason@bc
Post by Jason@bc »
Tried it, no succes, I guess I'll find another remote or something, thanks.
Granite
Post by Granite »
Have you tried it on a different computer? Perhaps they shipped you one with some bad keys.
6 cylinder puller
Post by 6 cylinder puller »
will it work with a torchmate?
This is basically a wireless keyboard. It should work with anything that would interface with a standard keyboard.
https://www.amazon.com/Upgraded-Rii-Wir ... B00Z81U3YY
Return to “Pen Markers, Remote Controls, Drawing Tablets, etc.”
