plasma arc do not stops right away
belloutiplasma
Post by belloutiplasma »
hello sir
i have a problem with my cnc plasma table
the plasma arc do not stops right away when finishing cutting of a piece
the torch moves to next pierce but torch do not stops right away
i attached a picture of a cutted piece it is supposed to start and end with quarter circle but it continues to cut a little bit more
i will be grateful if you can help me solve this problem
thank you
weldguy
Re: plasma arc do not stops right away
Post by weldguy »
Sticky relay in your controller? What equipment are you running?
If you are using SheetCam you may have the overcut set with a value. ;)
