Cutmaster 60i
Cutmaster 60i
Anyone have accurate location of J609 connector and pins 3 and 4 for connecting torch for plasma table. A photo location would be great. It would seem that Esab would wire a connector for cnc use in their machines. New to this type equipment. Sure would appreciate any help.
Re: Cutmaster 60i
Don't have a pic but I believe its the only 18 pin unused jumper block on the board so should be fairly easy to identify. If you need divided voltage you may want to look into the automation interface for it from Thermal Dynamics/Esab, it comes in the A series plasma units but not yours. C&CNC has one available also I believe.
Re: Cutmaster 60i
Found the J609 connector but do not see any method to determine terminal #3 and #4 from the 18 terminals on the connector.
Re: Cutmaster 60i
Does this help? Looks like some go to ground and some are empty so this should help you to determine the pins you need with a little testing.
Re: Cutmaster 60i
ESAB tech claims that if I connect to #3 and #4 terminals on the J609 connector for cnc relay that 60i should work. Connected to these terminals and torch will start but arc will not stop with relay until power is removed from 60i or relay wires are disconnected. I am using a Cutmaster 52 on the same cnc plasma table and it works great connected to the trigger start/stop switch which I assume is the same as #3 and #4 terminals. Any suggestions/help appreciated.plasmanewbie wrote: Thu Jun 13, 2019 12:04 pm Does this help? Looks like some go to ground and some are empty so this should help you to determine the pins you need with a little testing.
