SheetCam Error (with pic)
- Ironken
Re: SheetCam Error (with pic)
That's an odd one. Does it happen every time you run SheetCam?
- Ironken
First, thank you Les for responding so quickly! I have 2 seats of S.C., one on my laptop and one on the NUC of my JD2 MAD. This error is happening on my JD2 computer and yes, it is happening whenever I open S.C. Once I click o.k. everything functions fine and I go on with the job.
have you looked in the ini file (use a text editor, notepad or notepad++ etc)
post the ini file listed
- Ironken
robertspark wrote: Sun Jun 16, 2019 3:00 am have you looked in the ini file (use a text editor, notepad or notepad++ etc)
Thank you Robert for the advice. Unfortunately, I am a total moron when it comes to 'puters and what you are saying is Greek to me.
in the photo you posted there is a path c:\users....\xxxx.ini
if you follow the path you'll find the offending file.
when you find it, you can either view it to try to figure out what is wrong or post it here and maybe someone will take a look (you may need to rename the file from xxxx.ini to xxxxx.txt
If you go to Help->open settings folder it will take you to the folder containing the ini file. Could you either post it here or email it directly to me.
- Ironken
Thank You Les...here is what I found.
PosX=623
PosY=262
[Preferences]
Language=en_GB
EULAShown=2
ShowWizard=0
ReverseMouseWheel=0
VectsPerArrow=1
ArrowScale=1
TabScale=1
MinArrowSize=2
StartSize=5
AutoName=0
AllowNesting=1
GridX=5
GridY=5
BumpX=5
BumpY=5
DrillTolerance=0.1
BackupInterval=120
LinkTolerance=0.01
DetailReduction=0.02
CircleLimit=0.2
RemoveDuplicates=1
CircleMarker=4
startResolution=0.5
pierceClearance=1.5
startSnap=3
partBotLeft=1
fastDraw=0
checkUpdates=1
reverseAngles=0
bumpA=0.087266462599716
arcTolerance=0.1
arcSegs=4
bumpAngPlus=46
bumpAngMinus=44
minTabs=1
tabsInside=0
tabAngle=0
tabSpacing=200
alignTolerance=0.2
saveImageWithJob=0
graphDots=0
graphRulers=0
useDefaultTools=0
debugRules=0
softwareRender=0
saveImageType=15
XPosition=0
YPosition=0
width=0
Thickness=0
group=0
entrySnip=-1
exitSnip=0
feedRate=1
ReportTemplate=Jet report
RapidSpeed=2000
ToolTime=5
PierceTime=0
AllTools=0
[Preferences/MachineTypes]
Rotary\ cutting\ \(includes\ milling\ and\ routing\)=0
Jet\ cutting\ \(includes\ plasma\,\ laser\ and\ water\ jet\)=1
[Preferences/Printer]
MarginL=12
MarginT=12
MarginR=12
MarginB=12
CentreV=0
Collate=0
Bin=0
Colour=0
Duplex=0
NoCopies=1
Orientation=1
PaperId=3
PrinterName=
Quality=-1
PaperSize=3
SizeX=674
SizeY=500
Zoom=70
[Branding]
Day=58652
[Update]
SheetCam\ TNG\ Development=6.1.53
[MRU]
[MRU/Machine]
file0=C:\\Users\\Tech\\Documents\\Sheetcam Machines\\mad_44.machine
file1=
file2=
file3=
file4=
[MRU/Job]
file1=C:\\Users\\Tech\\Desktop\\Sheetcam Jobs\\Misc. Jobs\\Master Sgt 2.job
type1=
file2=C:\\Users\\Tech\\Desktop\\Sheetcam Jobs\\iPlanTables Jobs\\10-11g, Sheet 10.job
type2=
&10 C:\Users\Tech\Desktop\Temp Wall Mount\DXF\WM Inner Frame Upper Cover Plate.dxf
type3=
file4=
type4=
file5=
type5=
file6=
type6=
file7=
type7=
file8=
type8=
file9=
type9=
file10=
type10=
file3=C:\\Users\\Tech\\Desktop\\Sheetcam Jobs\\iPlanTables Jobs\\10-11g, Sheet 9.job
[MRU/Drawing]
file1=C:\\Users\\Tech\\Desktop\\iPlanTables DXF\\1 Upper Frame\\Parts\\003 End Cap, Pivot.dxf
type1=DXF files
file2=C:\\Users\\Tech\\Desktop\\iPlanTables DXF\\1 Upper Frame\\Parts\\014F Monitor Hook Mount Plate.dxf
type2=DXF files
file3=C:\\Users\\Tech\\Desktop\\DXF Cut Files\\Receiver Hitch\\Adjustable Hitch Tube.dxf
type3=DXF files
file4=C:\\Users\\Tech\\Desktop\\iPlanTables DXF\\1 Upper Frame\\Parts\\001 Gusset, Actuator Bracket.dxf
type4=DXF files
file5=C:\\Users\\Tech\\Desktop\\NONAME_0.dxf
type5=DXF files
file6=C:\\Users\\Tech\\Desktop\\iPlanTables DXF\\1 Upper Frame\\Parts\\018 Side Monitor Extension Plate, Outer.dxf
type6=DXF files
file7=C:\\Users\\Tech\\Desktop\\iPlanTables DXF\\1 Upper Frame\\Parts\\018 Side Monitor Extension Plate, Inner.dxf
type7=DXF files
file8=C:\\Users\\Tech\\Desktop\\Add To JD2 MAD\\Add To MAD PC\\Add To MAD PC\\Printer Plate.dxf
type8=DXF files
file9=C:\\Users\\Tech\\Desktop\\iPlanTables DXF\\1 Upper Frame\\Parts\\iPlanTables 16 Arial Bold.dxf
type9=DXF files
file10=C:\\Users\\Tech\\Desktop\\iPlanTables Front Name Plate.dxf
type10=DXF files
[MRU/Part]
file1=C:\\Users\\Tech\\Desktop\\iPlanTables DXF\\1 Upper Frame\\Parts\\018 Side Monitor Extension Plate, Outer.part
type1=
file2=D:\\iPlanTables DXF\\004 Plate, End.part
type2=
file3=D:\\DXF Cut Files\\004 Plate, End.part
type3=
file4=
type4=
file5=
type5=
file6=
type6=
file7=
type7=
file8=
type8=
file9=
type9=
file10=
type10=
[Dialogs]
[Dialogs/Machine\ options]
PosX=702
PosY=290
[Dialogs/Job\ options]
PosX=705
PosY=256
SizeX=526
SizeY=543
[Dialogs/Machine\ options\ -\ mad_44]
PosX=702
PosY=290
[Dialogs/Path\ rules]
PosX=699
PosY=395
SizeX=537
SizeY=265
[Dialogs/Jet\ cutting]
PosX=698
PosY=246
[Dialogs/Contour]
PosX=691
PosY=373
[Dialogs/Jet\ tool]
PosX=706
PosY=345
[Dialogs/Application\ options]
PosX=705
PosY=251
[Dialogs/Drill]
PosX=706
PosY=363
[Dialogs/Plugin\ options]
PosX=757
PosY=325
[Dialogs/Code\ snippet]
PosX=807
PosY=411
[RecentFiles]
[RecentFiles/PathRules]
Path=C:\\Users\\Tech\\Documents\\mad_tools\\mad_rules.rule
Type=Path rule set
[RecentFiles/Machine]
Path=C:\\Users\\Tech\\Documents\\Sheetcam Machines\\mad_44.machine
Type=Machine definition(*.machine)
[RecentFiles/Job]
Path=C:\\Users\\Tech\\Desktop\\Sheetcam Jobs\\Misc. Jobs\\Master Sgt 2.job
Type=Job files
[RecentFiles/Tools]
Path=C:\\Users\\Tech\\Desktop\\mad_tools\\hypertherm_powermax65\\finecut_mildsteel_air_air_cut_in.tools
Type=Tool set(*.tools)
[RecentFiles/Drawing]
Path=C:\\Users\\Tech\\Desktop\\iPlanTables DXF\\1 Upper Frame\\Parts\\003 End Cap, Pivot.dxf
Type=DXF files
[RecentFiles/Part]
Path=C:\\Users\\Tech\\Desktop\\iPlanTables DXF\\1 Upper Frame\\Parts\\018 Side Monitor Extension Plate, Outer.part
Type=Part files (*.part)
[RecentFiles/Job\ report]
[RecentFiles/Material]
[RecentFiles/Operation]
[Layout]
AUI=layout2|name=Post;caption=;state=11004;dir=1;layer=10;row=1;pos=0;prop=100000;bestw=92;besth=24;minw=-1;minh=-1;maxw=-1;maxh=-1;floatx=-1;floaty=-1;floatw=-1;floath=-1|name=File;caption=;state=11004;dir=1;layer=10;row=1;pos=137;prop=100000;bestw=368;besth=24;minw=-1;minh=-1;maxw=-1;maxh=-1;floatx=-1;floaty=-1;floatw=-1;floath=-1|name=Edit;caption=;state=11004;dir=1;layer=10;row=1;pos=516;prop=100000;bestw=23;besth=24;minw=-1;minh=-1;maxw=-1;maxh=-1;floatx=-1;floaty=-1;floatw=-1;floath=-1|name=View;caption=;state=11004;dir=1;layer=10;row=1;pos=550;prop=100000;bestw=276;besth=24;minw=-1;minh=-1;maxw=-1;maxh=-1;floatx=-1;floaty=-1;floatw=-1;floath=-1|name=Zoom;caption=;state=11004;dir=1;layer=10;row=2;pos=0;prop=100000;bestw=161;besth=24;minw=-1;minh=-1;maxw=-1;maxh=-1;floatx=0;floaty=85;floatw=186;floath=63|name=Mode;caption=;state=11004;dir=1;layer=10;row=2;pos=172;prop=100000;bestw=207;besth=24;minw=-1;minh=-1;maxw=-1;maxh=-1;floatx=-1;floaty=-1;floatw=-1;floath=-1|name=GLPanel;caption=Display;state=256;dir=5;layer=0;row=0;pos=0;prop=100000;bestw=20;besth=20;minw=-1;minh=-1;maxw=-1;maxh=-1;floatx=-1;floaty=-1;floatw=-1;floath=-1|name=VarMonitorPanel;caption=Variables;state=2099198;dir=4;layer=0;row=0;pos=2;prop=100000;bestw=247;besth=32;minw=20;minh=20;maxw=-1;maxh=-1;floatx=-1;floaty=-1;floatw=-1;floath=-1|name=LayerPanel;caption=Layers;state=2099196;dir=4;layer=0;row=0;pos=0;prop=100000;bestw=100;besth=80;minw=20;minh=20;maxw=-1;maxh=-1;floatx=1;floaty=101;floatw=388;floath=135|name=PartPanel;caption=Parts;state=2044;dir=4;layer=0;row=0;pos=1;prop=100000;bestw=100;besth=80;minw=20;minh=20;maxw=-1;maxh=-1;floatx=1;floaty=101;floatw=400;floath=250|name=Debug;caption=Debug;state=2099198;dir=3;layer=0;row=0;pos=0;prop=100000;bestw=379;besth=146;minw=20;minh=20;maxw=-1;maxh=-1;floatx=-1;floaty=-1;floatw=-1;floath=-1|name=ToolPane;caption=Tools;state=2044;dir=4;layer=0;row=0;pos=2;prop=100000;bestw=158;besth=63;minw=20;minh=20;maxw=-1;maxh=-1;floatx=-1;floaty=-1;floatw=-1;floath=-1|name=OperationPane;caption=Operations;state=2044;dir=4;layer=0;row=0;pos=3;prop=100000;bestw=126;besth=80;minw=20;minh=20;maxw=-1;maxh=-1;floatx=-1;floaty=-1;floatw=-1;floath=-1|name=CodePane;caption=Code editor;state=2099198;dir=3;layer=0;row=0;pos=0;prop=100000;bestw=200;besth=125;minw=-1;minh=-1;maxw=-1;maxh=-1;floatx=-1;floaty=-1;floatw=-1;floath=-1|name=BatchProcessing;caption=Quick load;state=2099198;dir=2;layer=0;row=0;pos=0;prop=100000;bestw=217;besth=306;minw=-1;minh=-1;maxw=-1;maxh=-1;floatx=-1;floaty=-1;floatw=-1;floath=-1|name=Plugins;caption=;state=11004;dir=1;layer=10;row=1;pos=103;prop=100000;bestw=23;besth=24;minw=-1;minh=-1;maxw=-1;maxh=-1;floatx=-1;floaty=-1;floatw=-1;floath=-1|name=DNC;caption=DNC;state=2099198;dir=4;layer=0;row=0;pos=0;prop=100000;bestw=253;besth=83;minw=20;minh=20;maxw=-1;maxh=-1;floatx=-1;floaty=-1;floatw=-1;floath=-1|name=Shape;caption=Shape;state=2046;dir=2;layer=0;row=0;pos=0;prop=100000;bestw=150;besth=193;minw=-1;minh=-1;maxw=-1;maxh=-1;floatx=-1;floaty=-1;floatw=-1;floath=-1|name=Simulation;caption=Simulation;state=2046;dir=2;layer=0;row=0;pos=0;prop=100000;bestw=142;besth=387;minw=-1;minh=-1;maxw=-1;maxh=-1;floatx=-1;floaty=-1;floatw=-1;floath=-1|name=Text;caption=Text;state=2046;dir=2;layer=0;row=0;pos=0;prop=100000;bestw=208;besth=446;minw=-1;minh=-1;maxw=-1;maxh=-1;floatx=-1;floaty=-1;floatw=-1;floath=-1|dock_size(5,0,0)=20|dock_size(4,0,0)=365|dock_size(1,10,1)=26|dock_size(1,10,2)=26|
[Layout/ValueTable]
Maximized=0
X=0.14805
Y=0.87632
Width=800
Height=600.351
[Layout/Main]
Maximized=1
X=0.83763
Y=0.87632
Width=800
Height=600.031
[PersistSelections]
81=0
15=1
71=0
18=0
19=1
59=1
20=1
21=1
22=1
23=1
58=0
32=0
66=1
75=1
707=0
60=0
[State]
View=
[TBars]
Bar0Name=Post
Bar0Data=0:1:79:773:
Bar1Name=File
Bar1Data=2:3:4:5:76:77:6:7:8:9:10:11:12:62:63:13:
Bar2Name=Edit
Bar2Data=14:
Bar3Name=View
Bar3Data=81:15:71:17:18:19:59:20:21:22:23:58:
Bar4Name=Zoom
Bar4Data=38:39:40:41:42:43:44:
Bar5Name=Mode
Bar5Data=46:47:48:82:49:50:68:827:842:
Bar6Name=Plugins
Bar6Data=745:
nBars=7
[Plugins]
[Plugins/Autoload]
lastTime=1.560878257e9
scanType=0
delayLoad=1
prevFile=
checkAtStart=0
enableDir=0
subDirs=0
dirName=
lastFile=
Enabled=1
[Plugins/BatchProcessing]
srcDir=
template=
sortType=0
showOptions=1
subDirs=0
fileType=0
useTemplate=1
disableOps=0
keepParts=1
[Plugins/DNC]
function=0
command=
inTerminal=0
keepOpen=0
port=0
baud=9600
parity=0
data=1
stop=0
flow=2
autoRun=0
Enabled=1
[Plugins/Sim]
Speed=500
Machine=Mill
RapidFeed=2000
FrameRate=20
ToolDia=1
MinDia=0
MaxFRO=500
ToolColOffR=127
ToolColOffG=127
ToolColOffB=127
ToolColCWR=255
ToolColCWG=255
ToolColCWB=255
ToolColCCWR=255
ToolColCCWG=255
ToolColCCWB=255
PolyDetail=1
Enabled=1
[Plugins/Mach]
ShowRemoteCtrl=1
Enabled=1
[Plugins/EdingCNC]
ShowRemoteCtrl=1
Enabled=1
[Plugins/Wire]
Enabled=1
[Plugins/VCarve]
Enabled=1
[Plugins/Text]
Enabled=1
[Plugins/SVG]
Enabled=1
[Plugins/shape]
Enabled=1
[Plugins/RotaryPlasma]
Enabled=1
[Plugins/moreposts]
Enabled=1
[Plugins/laser]
Enabled=1
[Plugins/Knife]
Enabled=1
[Plugins/HPGL]
Enabled=1
[Plugins/Gcode]
Enabled=1
[Plugins/Excellon]
Enabled=1
[Plugins/DXF]
Enabled=1
[Plugins/DSTV]
Enabled=1
[Plugins/calculator]
Enabled=1
[Plugins/BatchUpdate]
Enabled=1
[Plugins/Quickload]
Enabled=1
[Units]
Spindle\ speed=2000
Linear=in
Angular=degrees
Feed=ipm
RPM=rpm
Time=s
Pitch=TPI
[Colours]
Cut\ path=#00FF80
Feed\ override=#80FFFF
Rapid\ path=#3232CC
Inside\ shape=#FFFF00
Outside\ shape=#FF4040
Open\ paths=#C0C0C0
Line\ end=#FFFFFF
Segment\ end=#FFFFFF
Background=#000000
Machine\ working\ envelope=#404040
Machine\ table=#202020
Work=#400000
Material\ extents=#808080
Marker=#FFA000
Highlight=#FFFFFF
Duplicated\ part=#808080
Inactive\ part=#FF9300
Centre\ marker\ colour=#0000FF
Tabs=#0000FF
Grid=#606060
[Post]
Path=C:\\Users\\Tech\\AppData\\Roaming\\SheetCam TNG Development\\posts\\JD2_MAD.scpost
Units=1
OutputFolder=0
FileExtension=ngc
LastFile=C:\\Users\\Tech\\Desktop\\014F Monitor Hook Mount Plate.ngc
DefaultFile=
encoding=0
zZero=0
[Parts]
[Parts/ToolChange]
X=0
Y=0
Z=0
UseX=0
UseY=0
UseZ=0
Code=
BeforeCode=
noSafeZ=0
[Parts/Work]
Thickness=5.08
X1=0
X2=431.79999999999995
Y1=0
Y2=1219.1999999999998
Origin=6
Clearance=12.699999999999999
Bottom=0
isPolygon=0
polyLayer=
ParkX=0
ParkY=0
ParkZ=0
ParkUseX=0
ParkUseY=0
ParkUseZ=0
parkCode=
PlungeSafety=0.5
Notes=
Show\ Notes=0
Name=
polyPart=0
[Parts/Work/keepout]
Corner\ 1X=0
Corner\ 1Y=0
Corner\ 2X=0
Corner\ 2Y=0
Inside=1
Function=0
Clamp\ Clearance\ Height=RapidClearance
part=0
layer=
[Parts/Table]
TableX1=0
TableX2=1219.2
TableY1=0
TableY2=1219.2
X1=0
X2=1219.2
Y1=0
Y2=1219.2
MaxHeight=1000
Origin=6
tableOrigin=6
ToolTime=0
RapidSpeed=2000
[Parts/Misc]
optBias=0.5
Optimisation=1
[Parts/Cutoff]
Function=15
ID=-1
BelongsTo=-1
NameString=
Comment=
Enabled=0
Tool=1
LayerName=
Lead\ in=-1
Lead\ out=-1
Lead\ in\ type=0
Lead\ out\ type=0
CodeSnip=-1
Hole\ Size=0
Start\ point=0
Depth=0
Feed\ Rate=1.00076
Plunge\ Rate=99.999799999999993
Start\ depth=0
Climb\ cut=0
Finish\ allowance=0
cutBias=0.5
Reverse\ open\ paths=0
Auto\ Optimisation=1
offsetOpen=0
Leadins\ on\ open\ paths=0
Ignore\ rules=0
tabWidth=1.00076
Minimum\ X\ size=499.99899999999997
Minimum\ Y\ size=499.99899999999997
Maximum\ X\ size=2000.00108
Maximum\ Y\ size=2000.00108
Edge\ overlap=5.001259999999999
Grid\ size=49.999899999999997
Rectangular=0
[Parts/OpOrder]
Op000000=0,0
Op000001=0,1
Op000002=3,0
Op000003=3,1
Op000004=4,0
Op000005=4,1
Op000006=1,0
Op000007=1,1
Op000008=2,0
Op000009=2,1
Op000010=7,0
Op000011=7,1
Op000012=8,0
Op000013=8,1
Op000014=5,0
Op000015=5,1
Op000016=6,0
Op000017=6,1
Op000018=9,0
Op000019=9,1
Op000020=10,0
Op000021=5,1
Op000022=5,2
Op000023=11,1
Op000024=12,0
Op000025=12,1
Op000026=13,0
Op000027=13,1
Op000028=14,0
Op000029=14,1
Op000030=10,0
Op000031=10,1
Op000032=10,2
Op000033=11,0
Op000034=11,1
Op000035=11,2
Op000036=12,0
Op000037=12,1
Op000038=12,2
Op000039=13,0
Op000040=13,1
Op000041=13,2
Op000042=14,0
Op000043=14,1
Op000044=14,2
Op000045=15,1
Op000046=15,2
Op000047=16,1
Op000048=16,2
Op000049=17,1
Op000050=17,2
Op000051=18,1
Op000052=18,2
Op000053=19,1
Op000054=19,2
Op000055=20,0
Op000056=20,1
[Import]
ScaleFactor=25.399999999999999
Position=6
UseDwgName=1
UsePoints=1
UseColours=0
[Operations]
[Operations/JetOperation]
Type=JetOperation
ID=-1
BelongsTo=-1
Name=Jet cutting
Comment=
Enabled=1
Tool=18
Layer=1
Lead\ in=5.08
Lead\ out=5.08
Lead\ in\ type=1
Lead\ out\ type=1
CodeSnip=-1
Hole\ Size=31.75
Start\ position=0
Cut\ depth=0
Feed\ rate=2413
Plunge\ rate=99.999799999999993
Start\ depth=0
Contour\ method=1
Reverse\ cut\ direction=1
Finish\ allowance=0
Cut\ direction=0.5
Optimisation=1
Offset\ open\ paths=0
Cutting\ rules=0
Length=1.00076
Path\ rules=mad_pathrules
Loop\ size=5.24
Angle\ threshold=0.9
Loop\ corners=0
Max\ chain\ length=0
Minimise\ thermal\ distortion=0
Overcut=2.54
[Operations/JetOperation/Custom]
Skip\ Probe\ Distance=12.699999999999999
Fast\ Probe\ Distance=50.799999999999997
Min\ THC\ Line\ Length=6.35
[AnnoyingDialogs]
[AnnoyingDialogs/Running\ post\ processor]
Hide=1
[AnnoyingDialogs/Save\ default\ tool\ set]
Hide=1
Default=5101
[AnnoyingDialogs/Import\ drawing\ into\ new\ part]
Hide=1
Default=5103
[AnnoyingDialogs/Update\ operations\ when\ loading\ a\ tool\ set]
Hide=1
Default=5100
[Array]
SpacingMode=1
UseOfset=0
Cols=6
Rows=1
XSpace=9.524999999999999
YSpace=9.524999999999999
YOffset=0
[wxWindows]
[wxWindows/wxHtmlHelpController]
hcNavigPanel=1
hcSashPos=180
hcX=130
hcY=130
hcW=700
hcH=480
hcFixedFace=
hcNormalFace=
hcBaseFontSize=10
hcBookmarksCnt=0
[wxWindows/wxHtmlHelpController/wxHtmlWindow]
Borders=10
FontFaceFixed=
FontFaceNormal=MS Shell Dlg 2
FontsSize0=7
FontsSize1=8
FontsSize2=10
FontsSize3=12
FontsSize4=14
FontsSize5=17
FontsSize6=20
[Tools]
[Tools/Jet\ tool]
Type=LaserTool
Name=Jet tool
Comment=
Tool\ number=6
Kerf\ width=1.23952
Plunge\ rate=6350
Pierce\ delay=0.4
Pause\ at\ end\ of\ cut=0
Wiggle\ length=0
Pierce\ height=3.81
Cut\ height=1.524
Pierce\ type=0
Feed\ rate=6350
Power=78
Diameter=0.24892
Start\ delay=1
[Tools/Jet\ tool/Custom]
Attachment\ Number=6
Uses\ Z\ Axis=1
Requires\ Z\ Reference=1
[Tools/Code\ snippet]
Type=CodeTool
Name=Code snippet
Comment=
Tool\ number=268435456
Code=
PosX=623
PosY=262
[Preferences]
Language=en_GB
EULAShown=2
ShowWizard=0
ReverseMouseWheel=0
VectsPerArrow=1
ArrowScale=1
TabScale=1
MinArrowSize=2
StartSize=5
AutoName=0
AllowNesting=1
GridX=5
GridY=5
BumpX=5
BumpY=5
DrillTolerance=0.1
BackupInterval=120
LinkTolerance=0.01
CircleLimit=0.2
RemoveDuplicates=1
CircleMarker=4
startResolution=0.5
pierceClearance=1.5
startSnap=3
partBotLeft=1
fastDraw=0
checkUpdates=1
reverseAngles=0
arcTolerance=0.1
arcSegs=4
bumpAngPlus=46
bumpAngMinus=44
minTabs=1
tabsInside=0
tabAngle=0
tabSpacing=200
alignTolerance=0.2
saveImageWithJob=0
graphDots=0
graphRulers=0
useDefaultTools=0
debugRules=0
softwareRender=0
saveImageType=15
XPosition=0
YPosition=0
width=0
Thickness=0
group=0
entrySnip=-1
exitSnip=0
feedRate=1
RapidSpeed=2000
ToolTime=5
PierceTime=0
AllTools=0
MarginL=12
MarginT=12
MarginR=12
MarginB=12
CentreV=0
Collate=0
Bin=0
Colour=0
Duplex=0
NoCopies=1
Orientation=1
PaperId=3
PrinterName=
Quality=-1
PaperSize=3
SizeX=674
SizeY=500
Zoom=70
[Branding]
Day=58652
[Update]
[MRU]
[MRU/Machine]
file1=
file2=
file3=
file4=
[MRU/Job]
type1=
type2=
type3=
file4=
type4=
file5=
type5=
file6=
type6=
file7=
type7=
file8=
type8=
file9=
type9=
file10=
type10=
[MRU/Drawing]
type1=DXF files
type2=DXF files
type3=DXF files
type4=DXF files
type5=DXF files
type6=DXF files
type7=DXF files
type8=DXF files
type9=DXF files
type10=DXF files
[MRU/Part]
type1=
type2=
type3=
file4=
type4=
file5=
type5=
file6=
type6=
file7=
type7=
file8=
type8=
file9=
type9=
file10=
type10=
[Dialogs]
PosX=702
PosY=290
PosX=705
PosY=256
SizeX=526
SizeY=543
PosX=702
PosY=290
PosX=699
PosY=395
SizeX=537
SizeY=265
PosX=698
PosY=246
[Dialogs/Contour]
PosX=691
PosY=373
[Dialogs/Jet\ tool]
PosX=706
PosY=345
PosX=705
PosY=251
[Dialogs/Drill]
PosX=706
PosY=363
PosX=757
PosY=325
PosX=807
PosY=411
[RecentFiles]
Type=Path rule set
[RecentFiles/Job]
Type=Job files
[RecentFiles/Tools]
Type=DXF files
[RecentFiles/Part]
[Layout]
[Layout/ValueTable]
Maximized=0
X=0.14805
Y=0.87632
Width=800
Height=600.351
[Layout/Main]
Maximized=1
X=0.83763
Y=0.87632
Width=800
Height=600.031
[PersistSelections]
81=0
15=1
71=0
18=0
19=1
59=1
20=1
21=1
22=1
23=1
58=0
32=0
66=1
75=1
707=0
60=0
[State]
View=
[TBars]
Bar0Name=Post
Bar1Name=File
Bar2Name=Edit
Bar2Data=14:
Bar3Name=View
Bar4Name=Zoom
Bar5Name=Mode
Bar6Name=Plugins
Bar6Data=745:
nBars=7
[Plugins]
[Plugins/Autoload]
scanType=0
delayLoad=1
prevFile=
checkAtStart=0
enableDir=0
subDirs=0
dirName=
lastFile=
Enabled=1
srcDir=
template=
sortType=0
showOptions=1
subDirs=0
fileType=0
useTemplate=1
disableOps=0
keepParts=1
[Plugins/DNC]
function=0
command=
inTerminal=0
keepOpen=0
port=0
baud=9600
parity=0
data=1
stop=0
flow=2
autoRun=0
Enabled=1
[Plugins/Sim]
Speed=500
Machine=Mill
RapidFeed=2000
FrameRate=20
ToolDia=1
MinDia=0
MaxFRO=500
ToolColOffR=127
ToolColOffG=127
ToolColOffB=127
ToolColCWR=255
ToolColCWG=255
ToolColCWB=255
ToolColCCWR=255
ToolColCCWG=255
ToolColCCWB=255
PolyDetail=1
Enabled=1
[Plugins/Mach]
ShowRemoteCtrl=1
Enabled=1
[Plugins/EdingCNC]
ShowRemoteCtrl=1
Enabled=1
[Plugins/Wire]
Enabled=1
[Plugins/VCarve]
Enabled=1
[Plugins/Text]
Enabled=1
[Plugins/SVG]
Enabled=1
[Plugins/shape]
Enabled=1
Enabled=1
[Plugins/moreposts]
Enabled=1
[Plugins/laser]
Enabled=1
[Plugins/Knife]
Enabled=1
[Plugins/HPGL]
Enabled=1
[Plugins/Gcode]
Enabled=1
[Plugins/Excellon]
Enabled=1
[Plugins/DXF]
Enabled=1
[Plugins/DSTV]
Enabled=1
Enabled=1
Enabled=1
[Plugins/Quickload]
Enabled=1
[Units]
Spindle\ speed=2000
Linear=in
Angular=degrees
Feed=ipm
RPM=rpm
Time=s
Pitch=TPI
[Colours]
Cut\ path=#00FF80
Rapid\ path=#3232CC
Open\ paths=#C0C0C0
Line\ end=#FFFFFF
Background=#000000
Work=#400000
Marker=#FFA000
Highlight=#FFFFFF
Tabs=#0000FF
Grid=#606060
[Post]
Units=1
OutputFolder=0
FileExtension=ngc
DefaultFile=
encoding=0
zZero=0
[Parts]
[Parts/ToolChange]
X=0
Y=0
Z=0
UseX=0
UseY=0
UseZ=0
Code=
BeforeCode=
noSafeZ=0
[Parts/Work]
Thickness=5.08
X1=0
Y1=0
Origin=6
Bottom=0
isPolygon=0
polyLayer=
ParkX=0
ParkY=0
ParkZ=0
ParkUseX=0
ParkUseY=0
ParkUseZ=0
parkCode=
PlungeSafety=0.5
Notes=
Show\ Notes=0
Name=
polyPart=0
Corner\ 1X=0
Corner\ 1Y=0
Corner\ 2X=0
Corner\ 2Y=0
Inside=1
Function=0
part=0
layer=
[Parts/Table]
TableX1=0
TableX2=1219.2
TableY1=0
TableY2=1219.2
X1=0
X2=1219.2
Y1=0
Y2=1219.2
MaxHeight=1000
Origin=6
tableOrigin=6
ToolTime=0
RapidSpeed=2000
[Parts/Misc]
optBias=0.5
Optimisation=1
[Parts/Cutoff]
Function=15
ID=-1
BelongsTo=-1
NameString=
Comment=
Enabled=0
Tool=1
LayerName=
Lead\ in=-1
Lead\ out=-1
Lead\ in\ type=0
Lead\ out\ type=0
CodeSnip=-1
Hole\ Size=0
Start\ point=0
Depth=0
Feed\ Rate=1.00076
Start\ depth=0
Climb\ cut=0
Finish\ allowance=0
cutBias=0.5
offsetOpen=0
Ignore\ rules=0
tabWidth=1.00076
Rectangular=0
[Parts/OpOrder]
Op000000=0,0
Op000001=0,1
Op000002=3,0
Op000003=3,1
Op000004=4,0
Op000005=4,1
Op000006=1,0
Op000007=1,1
Op000008=2,0
Op000009=2,1
Op000010=7,0
Op000011=7,1
Op000012=8,0
Op000013=8,1
Op000014=5,0
Op000015=5,1
Op000016=6,0
Op000017=6,1
Op000018=9,0
Op000019=9,1
Op000020=10,0
Op000021=5,1
Op000022=5,2
Op000023=11,1
Op000024=12,0
Op000025=12,1
Op000026=13,0
Op000027=13,1
Op000028=14,0
Op000029=14,1
Op000030=10,0
Op000031=10,1
Op000032=10,2
Op000033=11,0
Op000034=11,1
Op000035=11,2
Op000036=12,0
Op000037=12,1
Op000038=12,2
Op000039=13,0
Op000040=13,1
Op000041=13,2
Op000042=14,0
Op000043=14,1
Op000044=14,2
Op000045=15,1
Op000046=15,2
Op000047=16,1
Op000048=16,2
Op000049=17,1
Op000050=17,2
Op000051=18,1
Op000052=18,2
Op000053=19,1
Op000054=19,2
Op000055=20,0
Op000056=20,1
[Import]
Position=6
UseDwgName=1
UsePoints=1
UseColours=0
[Operations]
Type=JetOperation
ID=-1
BelongsTo=-1
Name=Jet cutting
Comment=
Enabled=1
Tool=18
Layer=1
Lead\ in=5.08
Lead\ out=5.08
Lead\ in\ type=1
Lead\ out\ type=1
CodeSnip=-1
Hole\ Size=31.75
Start\ position=0
Cut\ depth=0
Feed\ rate=2413
Start\ depth=0
Contour\ method=1
Finish\ allowance=0
Cut\ direction=0.5
Optimisation=1
Cutting\ rules=0
Length=1.00076
Loop\ size=5.24
Loop\ corners=0
Overcut=2.54
[AnnoyingDialogs]
Hide=1
Hide=1
Default=5101
Hide=1
Default=5103
Hide=1
Default=5100
[Array]
SpacingMode=1
UseOfset=0
Cols=6
Rows=1
YOffset=0
[wxWindows]
hcNavigPanel=1
hcSashPos=180
hcX=130
hcY=130
hcW=700
hcH=480
hcFixedFace=
hcNormalFace=
hcBaseFontSize=10
hcBookmarksCnt=0
Borders=10
FontFaceFixed=
FontsSize0=7
FontsSize1=8
FontsSize2=10
FontsSize3=12
FontsSize4=14
FontsSize5=17
FontsSize6=20
[Tools]
[Tools/Jet\ tool]
Type=LaserTool
Name=Jet tool
Comment=
Tool\ number=6
Kerf\ width=1.23952
Plunge\ rate=6350
Pierce\ delay=0.4
Wiggle\ length=0
Pierce\ height=3.81
Cut\ height=1.524
Pierce\ type=0
Feed\ rate=6350
Power=78
Diameter=0.24892
Start\ delay=1
Uses\ Z\ Axis=1
Type=CodeTool
Name=Code snippet
Comment=
Code=
That is really odd. I found the error but I am surprised it didn't automatically get fixed next time you closed SheetCam. I have attached a zipped copy of the fixed file.
- Attachments
- SheetCam TNG Development.zip
- (5.03 KiB) Downloaded 56 times
- Ironken
Thank you for fixing the file, Les. I'm not great with computers, do I delete the corrupt file and replace it with your file? If so, could you give guidance on how to do so?
to give you a quick reply, download the zip file Les sent to a folder of you choice.
The locate the bad file by going to the location C:\Users\Tech\AppData\SheetCam TNG Development the look for the file SheetCam TNG Development.ini, then click on it and delete it or rename it by changing the ini to .old, or .bad. The SheetCam program will not look for that name.
Now unzip the attachment Les sent and tell it to unzip to C:\Users\Tech\AppData\SheetCam TNG Development, this should correct the problem you have. To unzip you may use the extract to function if using WinRAR free download program for unzipping.
- Ironken
I owe you one, Jester! Thank you so much for the help.
You guys are awesome. Love it
Happy to help, Les did the hard stuff
- Ironken
Still getting the same error after the new file install. Any other ideas? Anybody, anybody, Bueller? Bueller?
Here is where the new file went.
- Ironken
I wanted to make sure to say that Les did get me taken care of via email.....didn't want it to look like he ignored my last post.
Thank you to everybody for the help!
