Rotating an Entire Nest
Ironken
Post by Ironken »
I have jobs saved in Sheetcam that are 4x4 sheets nested with several different parts that have been duplicated or arrayed. I would like to rotate the entire sheet of nested parts in one action but all I know how to do is one part at a time. I have about a dozen different nests saved and this is far too time consuming.
Is there a way to rotate the entire sheet of parts?
Some parts have long cuts that occasionally line up with the slats and cause cut issues thus, I want to rotate the entire sheet 90 deg to reduce the issue.
Any ideas?
JD2 MAD 4X4
Millermatic 252 (spray)
Millermatic 190 (short circuit)
Syncrowave 210
Powermax 65
Powermax 45xp
Grizzly Vertical Mill (junk)
Baileigh BS-210M
50t Press
Shitloads of DeWalt
djreiswig
Re: Rotating an Entire Nest
Post by djreiswig »
You could probably accomplish this by editing your post processor and swapping the x and y moves.
Ironken
Post by Ironken »
djreiswig wrote: Wed Nov 13, 2019 8:23 pm You could probably accomplish this by editing your post processor and swapping the x and y moves.
Good idea DJ....I'll take a chop at it. Thank you.
JD2 MAD 4X4
Syncrowave 210
Powermax 65
Powermax 45xp
Baileigh BS-210M
50t Press
Shitloads of DeWalt
Les Newell
Post by Les Newell »
In nesting mode use your mouse to drag a box over all of the parts. That selects all parts. Now use the < and > keys to rotate the group. You can also drag the group around if you need to reposition them.
Ironken
Post by Ironken »
Les Newell wrote: Thu Nov 14, 2019 6:41 am In nesting mode use your mouse to drag a box over all of the parts. That selects all parts. Now use the < and > keys to rotate the group. You can also drag the group around if you need to reposition them.
Thank you Les. I always selected with the box and entered the degrees making only the original part rotate. Ill try the arrows.
JD2 MAD 4X4
Syncrowave 210
Powermax 65
Powermax 45xp
Baileigh BS-210M
50t Press
Shitloads of DeWalt
djreiswig
Post by djreiswig »
I'll have to remember that. I didn't know you could select multiple parts at once.
Les Newell
If you hold the <ctrl> key and click on multiple parts you can select them that way as well. Useful if you want to only move/rotate a few parts.
As usual you never stop learning, thanks Les, once again we see what a great software package you have developed.
I was not sure about doing this (the dummy I am :Sad ) so I followed your instructions and wala slam dunk, :Yay here are 2 screen screenshots.
rotate 2.JPG (75.73 KiB) Viewed 763 times
Return to “SheetCam”
