Air Dryer
infinitydesigns
Air Dryer
Post by infinitydesigns »
What is a good air dryer for my compressor? Looking @ something small
AnotherDano
Re: Air Dryer
Post by AnotherDano »
I use a Motor Guard following a glass-bowl water separator, for powder coating and general shop use. And another in-line for the plasma cutter.
Dano Roberts
droberts@ironpequod.com
PlasmaCam DHC-2 v3.11
Hypertherm PowerMax-30
jmsrbrt
Re: Air Dryer
Post by jmsrbrt »
You might look at Harbor Freight. They sell, and I have, a dessicant dryer that is about 2-3" in diameter and three feet long (give or take). Takes several pounds of dessicant, the only drawback is there is no view window to tell when the dessicant needs changing. Bob.
I also run my air through 50 feet of tubing before it hits the dryer to help cool off the hot air.
