New problem guys, when I Import a DXF file into Sheetcam and measure it, it shows like 0.1 etc.
It just started doing this, worked fine before but now Sheetcam doesn't show the true measurements.
I uninstalled Sheetcam and reloaded it, but measure are not working
Thanks in advance for any help on what happened.
PS
Incorrect measurements when opening files
Windows 10 64 bit laptop
Gorilla 4x4 table
Proma torch height control
Gecko mini gender changer to USB
Everlast 80 S Plasma cutter
Mach3
Inkscape
QCAD.
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Re: Measuring
Do you have the scaling set correctly when you import your drawing? It is more likely that your drawing is loading the wrong size than measure showing the wrong dimensions.
Re: Measuring
Thanks Les
These are dxf files resized in Inkscape and saved.
I don’t know what’s happening.
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Re: Measuring
It sounds like the resizing didn't work correctly. Using the results of teh measure tool you should be able to work out what scale factor you need. It may be better to load the dxf files directly rather than trying to resize them in Inkscape.
Re: Measuring
Thanks Les
it was the scale factor change it from 1.1 to 1.25 and they are working in Sheetcam now
Thanks for the help
Thanks for the help
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
