20mm (3/4 inch) mild steel plate cut with powermax 105
arumalla58
Post by arumalla58 »
Hi,
Could you please help out in cutting of 20mm thick mild steel plate with Hypertherm powermax 105 amps.
what are the parameters i have to set ?
VR
Old Iron
Re: 20mm (3/4 inch) mild steel plate cut with powermax 105
Post by Old Iron »
Google for a Powermax 105 manual. All the settings are in it.
Or just download the file I posted below.
OM_807390_R3_Powermax105.pdf
(5.74 MiB) Downloaded 44 times
weldguy
Post by weldguy »
Or shortcut right to cut charts available here https://www.plasmaspider.com/Powermax 105 Cut Charts
arumalla58
thanks
