Copper Sulfate Pentahydrate
Learn and share patina finishing techniques, experiences, and product knowledge here.
_jay_
Post by _jay_ »
Hi,
Has any one used Copper Sulfate Pentahydrate (CuSO4.5H2O) to make patinas on CR steel ?
Seems to create transfer of copper ions thus covering the metal surface with copper.
The learning curve is exponential AKA "never ends " !
Nacs Fab
Re: Copper Sulfate Pentahydrate
Post by Nacs Fab »
I bought some Copper Sulfate and mixed it in with distilled water and it produced copper on steel, but i just cannot get the mix ratio right enough to suit me. I just decided its much more consistent to use Steel FX Products rather than wasting time messing up artwork.
G540 with LCTHC by candcnc
all built... by me...
4Dscreenart
Post by 4Dscreenart »
I use copper sulfate all the time. As far as consistency just use the same measurement every time. I use 1/4 cup per gallon shake it up good and pour it into a spray bottle as needed.
GOME
Post by GOME »
Try adding a tablespoon of sulfuric acid with your copper sulfate, you will be amazed at the durability, consistency, and speed with which the copper plates out.
AREA
Post by AREA »
GOME wrote: Wed Mar 23, 2022 9:25 am Try adding a tablespoon of sulfuric acid with your copper sulfate, you will be amazed at the durability, consistency, and speed with which the copper plates out.
I will give that a try, thanks for the tip.
DIY 2x2 table
Everlast 82i
Return to “Patina Finishes”
