Downdraft fan size question
IUCTX
Post by IUCTX »
I am trying to find the best type and size fan to exhaust the smoke/fumes/dust from my table. The table is 6x12 and has a v-shaped basin. Suspended halfway between the basin bottom and the cutting surface is a 7" ID steel pipe with 8ea 4" square 'ports'. There is only one outlet on the table located on one end. The table will be situated in my shop in such a way that the outlet of this pipe is 8' from the exterior wall, at 90 degrees from where I need to vent.
I have read good things about backward incline blowers. Any input on what size and type fan as well as connection methods will be much appreciated.
EDIT: typo
cuttinparts
Re: Downdraft fan size quesion
Post by cuttinparts »
Man I don't have any suggestion on a fan for you but holy crap man that is a sick build! So well thought out and executed. Well done :Like :Like
IUCTX
Post by IUCTX »
cuttinparts wrote: Tue Nov 03, 2020 10:24 am So well thought out and executed.
Except for the exhaust fan part! :HaHa
cuttinparts
Lol, ya I suppose. Oh well when you find the right fan for the job this is going to be sick!
rcummings54
Re: Downdraft fan size question
Post by rcummings54 »
Just curious IUCTX, were you able to find a fan that worked for your downdraft setup?
IUCTX
Post by IUCTX »
rcummings54 wrote: Thu Jul 08, 2021 4:05 pm Just curious IUCTX, were you able to find a fan that worked for your downdraft setup?
Yes, I ended up going with this high pressure blower with a 5HP motor.
