Help needed
Re: Help needed
Assuming your file was drawn in metric (mm), the overall height is about 25 inches. What size are you planning to cut it? The overall size and kerf width will dictate what detail can be produced. What material thickness are you using?
Re: Help needed
OK. So about 24" tall. Which features are you willing to leave out?
Re: Help needed
OK. Laser vs. plasma makes a huge difference (laser more precise with less heat and very narrow kerf). You do realize that you have two separate parts. Here is the outer perimeter of the cut.
Re: Help needed
In what manner does it "mess up"?
Re: Help needed
Do you want to connect the upper and lower parts for a single piece?
Re: Help needed
He could also do some laser engraving for some of the details. I have this done with some of my parts by the local cnc laser shop. They can very the pulse width and power to create different effects with the "engraving". You would need to specify to your programmer which paths would receive this treatment.
Re: Help needed
Your original dxf file had very many intersections, which could have also potentially contributed to your problems cutting. I have cleaned up your file and eliminated all intersections, which may also help. I will submit the new file after we decide on the editing format to eliminate some of the details you referred to.
Re: Help needed
Decide if you want any of the cut paths laser etched instead of cut, then tell me exactly which of the other cut paths (if any) you want deleted. As it is 3:15AM in Tucson, Arizona, USA - and I am about ready to call it a night, I will get back with you tomorrow (about 12-15 hours from now) to respond and edit your file.
Re: Help needed
Oggy2para wrote: Tue Nov 17, 2020 5:41 am Haha you get to bed mate that’s late 👌
Nothing can be etched as it needs to be painted after. All the lines in the scroll can be deleted. All the detail in the rope around the anchor can be deleted. The detail at the bottom of the crown also.
Something like this?
Re: Help needed
Re: Help needed
Oggy2para wrote: Tue Nov 17, 2020 5:37 pm Nearly, I think we need a few leaves in there and maybe just the outline of the continents ?
This is my WhatsApp if that’s easier ?
07714257005
Let's go ahead and take this "off-line". You can contact me via email at desert.hybrids@cox.net to continue our discussion.
Re: Help needed
Email received.
