dxf designer needed
tannje3
dxf designer needed
Post by tannje3 »
Hello all,
I am looking for someone that can put about 4 designs together rather soon in dxf. I have all the images and files. Just needing them put together so we can cut them. and yes I'm willing to pay for your service, thank you.
Re: dxf designer needed
there are a few here that do contract work, here is one http://robinhillmachine.com
Xtreme metal
Post by Xtreme metal »
You can send them to me. M e-mail is mgarriott@customtruck.com
Tracker CNC Nitro
Miller Matic 251
Miller Shop Mate 350
FEAR NOT!!!
Michael Garriott
Cz_apie
Post by Cz_apie »
tannje3 wrote: Tue Dec 22, 2020 12:03 pm Hello all,
send the files an I will see what I can do for you
Plasmacam 4x4 DHC2 Table
If you go ahead and upload your files and tell us what you want, myself or a fellow member can take a look to see if we can help you out. If these are pretty simple, then no charge to help out a fellow member.
tannje3
Post by tannje3 »
I do own these files. just trying to put the 2 trucks into the frame. These files were not cnc ready. Is the only way to "tab" the pieces together in a cad program with lines and such? or is there an easier way in like inkscape. my trouble is not getting files into dxf format but tabbing them in some way other than hours of lines in Qcad. Thank you
tannje3
Post by tannje3 »
Here is my other problem. The file is ok but in cad there are 2 many points, which for me translate into like 160 pierce points. is there a way to fix this? I am not looking for free work done here, if you can learn me here that would be great, if not let me know what it would cost, thanks.
I can not attach the dxf of this to big, here is svg before i put into dxf.
tannje3 wrote: Thu Dec 24, 2020 8:31 pm I do own these files. just trying to put the 2 trucks into the frame. These files were not cnc ready. Is the only way to "tab" the pieces together in a cad program with lines and such? or is there an easier way in like inkscape. my trouble is not getting files into dxf format but tabbing them in some way other than hours of lines in Qcad. Thank you
I assume you are looking for something like this with one truck per frame. I know of no magic quick method to "tab" these for cutting. I would need to do this manually.
tannje3 wrote: Thu Dec 24, 2020 8:37 pm Here is my other problem. The file is ok but in cad there are 2 many points, which for me translate into like 160 pierce points. is there a way to fix this? I am not looking for free work done here, if you can learn me here that would be great, if not let me know what it would cost, thanks.
The lower left hand portion of you svg has a box drawn over it, but here is what we have. This file would really need more clean-up in order to produce a nice result when cut. You are welcome to PM me if you require further assistance.
Lots of intersections here.
After linking/joining.
Now only 8 pierce points for lakes portion.
table rock lake dxf from de.dxf
tannje3
Post by tannje3 »
thank you, i will get to work on the manual tabbing for the trucks. On the lake file can i ask how and what you used to get rid of all the points.
tannje3 wrote: Fri Dec 25, 2020 11:54 am On the lake file can i ask how and what you used to get rid of all the points.
Combination of Inkscape, Paint.net, and Design Edge.
Cz_apie
Post by Cz_apie »
tannje3 wrote: Fri Dec 25, 2020 11:54 am thank you, i will get to work on the manual tabbing for the trucks. On the lake file can i ask how and what you used to get rid of all the points.
Hi
Might also help if you mention the size of final design that you require, size of tabs need to withstand cutting and if a dfx file become to big you can put it into a RAR to extract like this one were 3.6mb in DFX and to big to add and once in RAR only 815kb
clement 11111.rar
Nice work! Here it is as a pcm for you Plasmacam folks.
clements 2018 pcm.pcm
