Does anyone have this file that is cut ready??? I tried this one but it has alot of broken lines or broken lines i cant seem to catch them when i take it over to sheetcam.
dont tread on me clean file
4x4 Crossfire Pro Cnc Table
Hypertherm Powermax 45xp
ViaCad2D
ViaCad2D
Re: dont tread on me clean file
I looked at your file and there are a few dots which may be causing a problem when you plan in SheetCam. You can move them to another layer in SheetCam and uncheck that layer. I did also use a internet DXF to SVG conversion program, and boy did it screw it up, this tells me the original files was saved with a program that has a different format for the DXF then other programs may not be able to open cleanly.
Looks like it could be a splines issue. SheetCam doesn't seem to like splines. Have to convert them to polylines.
- Larry83301
Try this file and see if it's better. Sometimes saving as an R14 works for most people.bp4511 wrote: Mon Feb 01, 2021 12:52 am Does anyone have this file that is cut ready??? I tried this one but it has alot of broken lines or broken lines i cant seem to catch them when i take it over to sheetcam.
Don't tread on me.dxf
Your file opened fine for me with Design Edge. It did have many intersections that were joined together when I linked it.bp4511 wrote: Mon Feb 01, 2021 12:52 am Does anyone have this file that is cut ready??? I tried this one but it has alot of broken lines or broken lines i cant seem to catch them when i take it over to sheetcam.
I tried and still a disaster I downloaded the file from this forum, it still wont open correctly. Thankyou Larry
Larry83301 wrote: Mon Feb 01, 2021 10:24 amTry this file and see if it's better. Sometimes saving as an R14 works for most people.bp4511 wrote: Mon Feb 01, 2021 12:52 am Does anyone have this file that is cut ready??? I tried this one but it has alot of broken lines or broken lines i cant seem to catch them when i take it over to sheetcam.
Don't tread on me.dxf![]()
DON'T TREAD ON ME-1.DXF
ViaCad2D
ViaCad2D
Thank you David for looking at it as well I thought I corrected all broken lines but they still throw an error. I'm a beginner so its super steep curve my cad software is ViaCad. Its pretty simple but maybe i need something with better tools in it to fix this????
adbuch wrote: Mon Feb 01, 2021 4:27 pmYour file opened fine for me with Design Edge. It did have many intersections that were joined together when I linked it.bp4511 wrote: Mon Feb 01, 2021 12:52 am Does anyone have this file that is cut ready??? I tried this one but it has alot of broken lines or broken lines i cant seem to catch them when i take it over to sheetcam.
don't tread on me.dxf
ViaCad2D
ViaCad2D
This one opens fine for me. Only 6 intersections and should cut fine. I am thinking this may be a problem with the method Larry is using to process the file with Sheetcam.
- Larry83301
I used MasterCam to open the original file and then saved it back as an AutoCad R 14. I did not even try to edit the file at all asI did not deed it right now, but I did look at it and it looked cuttable to me.adbuch wrote: Tue Feb 02, 2021 3:36 pm This one opens fine for me. Only 6 intersections and should cut fine. I am thinking this may be a problem with the method Larry is using to process the file with Sheetcam.
Thank you to both of you for your time and for helping me.
ViaCad2D
ViaCad2D
