Wheelin for Warriors Jeep Firepit
Moe4x4
Post by Moe4x4 »
I can't believe I am making this my first post here. I'm new to plasma cutting but I have been working with a vinyl cutter for a while. I am building a fire pit for a charity raffle and am struggling to get the logo onto it. I'm struggling with how to make it work right. I will be cutting it out of 11 gauge steel on an eagle plasma table. The top most one that I have is about the size that I would like to get.
I have tried some of the tricks that I have found on here but still just can't wrap my head around this one.
Thanks In Advance for the help.
TJ
jmersereau
Re: A little help needed.
Post by jmersereau »
Are you looking for a single layer of steel or do you want layered? If it is a single layer then you have to bridge at least once across every line so things don't drop out.
I'll play around with it, I am sure there are better and faster people on the site but I like to challenge myself.
Jim
PrimeWeld CUT60
Langmuir CrossFire Pro
Moe4x4
Post by Moe4x4 »
Jim I appreciate it. single layer. I'm thinking of putting it on the roof of the fire pit so it will act like a grill instead of the tire tread grill pattern. I tried Bridging it but couldn't figure out a good way to make it look good. I'm usually pretty good at visualizing stuff and how it will cut but can't wrap my head around this one.
It is not clear to me which one of your designs you want as your finished file. For the upper one in your svg, this is what it looks like (as is) when cut into a sheet of material. If the letters were converted to "stencil" format so the centers of the A, O, R, etc. don't fall out, then you would just need to work on the scene below (jeep, mountains, etc). I think this is very "doable" with a little time and effort.
Moe4x4
Post by Moe4x4 »
David, what program did you use to do that. That makes it easier for me to see also. And could work with that. Jim helped me out also. I really appreciate your help.
djreiswig
Post by djreiswig »
I'm guessing that's DesignEdge. He seems to have a bunch of PlasmaCam tables.
Moe4x4 wrote: Sat Mar 06, 2021 6:44 pm David, what program did you use to do that. That makes it easier for me to see also. And could work with that. Jim helped me out also. I really appreciate your help.
I used Plasmacam Design Edge for the file above. I normally use a mix of paint.net, inkscape, and Design Edge for the files I work on. Is the file I showed above the format you are looking for?
Here it is with the letters converted to stencil and a few other mods. See if this is something you can use, if you don't already have one you like.
wheeling for warriors dxf.zip
Moe4x4
Post by Moe4x4 »
David, Thank you very much. between yours and what Jim Helped me out with I know I can now get it figured out the way I want it to look exactly. Thank you both for all the help. I really appreciate it. I'm hoping to get it cut this week. but with all the other projects in the shop i will see what happens.
Thank you both again. I will try and remember to post up the final cut and built version of it for the raffle.
Moe4x4
Post by Moe4x4 »
ok here is the finished product.
will be raffled off in the Wheeling for Warriors event in June
Thank you guys for the help.
Re: Wheelin for Warriors Jeep Firepit
You are welcome! Thanks for posting your final result. It looks great!
Moe4x4
Post by Moe4x4 »
Thanks you are welcome. you guys helped me a bunch so I wanted to make sure you got to see it.
authenticwrench
Post by authenticwrench »
I am going to this same event and also have a donation I want to do that uses this logo. I tried downloading it and opening it but the file has tons of over lapping lines. Any help in getting a simplified dxf version of it or help on how to clean it up?
authenticwrench wrote: Sat May 01, 2021 2:24 pm I am going to this same event and also have a donation I want to do that uses this logo. I tried downloading it and opening it but the file has tons of over lapping lines. Any help in getting a simplified dxf version of it or help on how to clean it up?
What software are you attempting to open the file with? I just opened the dxf posted above with Design Edge and No Overlaps or Intersections. I have attached it again below for your convenience.
authenticwrench
adbuch wrote: Sat May 01, 2021 9:10 pm
i am using viacad to open it and modify it for what i need, its being done on an older computer and it froze the computer when trying to open it. i will try this new one and see how it goes, i appreciate the help i am still new to all of this.
It's a pretty large file (2.31 Mb) so it is very possible that your older computer has insufficient memory or some other problem. The file could possibly be simplified (by deleting some of the detail).
djreiswig
Post by djreiswig »
Is it just me, or is that a right hand drive Jeep?
authenticwrench
adbuch wrote: Sun May 02, 2021 10:40 pm It's a pretty large file (2.31 Mb) so it is very possible that your older computer has insufficient memory or some other problem. The file could possibly be simplified (by deleting some of the detail).
yeah my computer cant open it and i am still very new to this and i am trying to learn. if anyone could help me simplify this down it would be much appreciated.
What details are you willing to delete?
authenticwrench
i would say most of the front tire detail can go keep the rim and no rear tire at all. i want to incorporate this into a flag.
adbuch wrote: Tue May 04, 2021 4:55 pm What details are you willing to delete?
authenticwrench wrote: Thu May 06, 2021 4:54 pm i would say most of the front tire detail can go keep the rim and no rear tire at all. i want to incorporate this into a flag.
This one just might work for you. It still has all the details, but the file size is now only around 780 KB.
wheeling for warriors rev. 1.dxf
authenticwrench
i really appreciate the help, i do want to learn how to do this but i am still new to it and i am good at the metal fab side, the programming is something is going to take me time.
adbuch wrote: Thu May 06, 2021 8:06 pm
Let me know if you are able to open this one. It is not necessary to open it with Viacad. Just load the dxf into your Sheetcam (or equivalent) and create the cut paths and start cutting.
authenticwrench
i want to add this into a flag so i need to open it in something that i can edit it with.
adbuch wrote: Fri May 07, 2021 4:39 pm Let me know if you are able to open this one. It is not necessary to open it with Viacad. Just load the dxf into your Sheetcam (or equivalent) and create the cut paths and start cutting.
You should be able to open the dxf in LightBurn or your favorite vector editor. Or you could convert the dxf to svg format and edit with Inkscape.
Or - post your flag dxf file and let us know where you want it placed in your flag.
