Anyone experience this?
The shield deformation is from trying to dig out the stuck threads to save the shield.
Whoops...
- ROKCRLER
Whoops...
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
Re: Whoops...
It looks like you broke the threaded end off of your retaining cap. Perhaps some sort of lubricant on the threads would help to prevent this.
Re: Whoops...
I had one start to arc out the side above the threads. I was having problems piercing and happened to catch it. Swapped it out and things worked much better.
- ROKCRLER
Re: Whoops...
I use DOW Corning 111 valve lubricant on all o-rings and threads.
I have been cutting quite a bit at 65a-85a lately and age of the the two parts are.
I keep one assembly for fine cuts and one for regular.
now I make sure I have spares.
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
Re: Whoops...
Rokcrler wrote: Sun Apr 03, 2022 2:39 pm I use DOW Corning 111 valve lubricant on all o-rings and threads.
Re: Whoops...
I have never experienced that. Must be too many heat cycles and it finally let go. Spares are always good to have no doubt!
Re: Whoops...
Same here. I've never had a problem with the threads in the cap.weldguy wrote: Mon Apr 04, 2022 11:47 am I have never experienced that. Must be too many heat cycles and it finally let go. Spares are always good to have no doubt!
