EasyScriber for Primeweld Cut60
Does anybody know if there's a way to make an EasyScriber work the with the PW Cut60? Or know of another scriber that would work with it?
Re: EasyScriber for Primeweld Cut60
If you have a way to attach an optional scribe to you Z axis there are solutions.
Did you buy that or build it yourself? I can figure out a way to add to my Z axis
I make them, if you have a 3-D printer I will give you the STL files to print the parts. The diamond engraver tip are easy to find. You will need a metal lathe to bore the hole for the tip, if you want to make your own.
I use a flat bar to attach it to the Z axis.
Depending on the size of your consumable stack, you might be able to 3D print an adapter sleeve to fit the EasyScriber into your torch.oldhousefab wrote: Thu Aug 04, 2022 7:33 am Does anybody know if there's a way to make an EasyScriber work the with the PW Cut60? Or know of another scriber that would work with it?
I did make another style to go over the machine torch.
Thats pretty cool!! I have the cut 60 too, I just have the hand held haven't got the pencil torch yet!acourtjester wrote: Thu Aug 04, 2022 1:42 pm I make them, if you have a 3-D printer I will give you the STL files to print the parts. The diamond engraver tip are easy to find. You will need a metal lathe to bore the hole for the tip, if you want to make your own.
RAYZORcut
