Ohmic Sensor
BleedBlue
Ohmic Sensor
Post by BleedBlue »
Considering purchasing an Arclight table. Does anybody know if you can add the ohmic sensor to the table? Also, would
you be able to turn it off in cnccommand? Thanks for the replies.
Re: Ohmic Sensor
Post by jimcolt »
Best bet is to call Arclight Dynamics. They have always used the cnc controls from www.candcnc.com, which use Ohmic contact. (they call it "Feathertouch". Jim Colt Hypertherm
BleedBlue
Re: Ohmic Sensor
Post by BleedBlue »
Thanks Jim for the reply. I did call them, but their answer
was a little vague. They said they haven’t perfected it yet.
Just thought maybe somebody on this forum would have tried to add it.
tcaudle
Re: Ohmic Sensor
Post by tcaudle »
The ohmic can be setup in conjunction with the mechanical switch (defined as a HOME) to be the touch off nbackup. Works like this: When you call for a Home (reference) it uses just the switch and applies the switch offset. When you call for a Touch off it watches the input the Ohmic is tied to first then if it misses it uses the mechanical switch (with applied offset) as the touch off. A touch off is a PROBE function NOT a HOME.
BleedBlue
Re: Ohmic Sensor
Post by BleedBlue »
Thanks for the clarification.
