Precision milled frames
Star-Lab plasma table discussion forum
BTA Plasma
Post by BTA Plasma »
We started bridge machining 100% of our frames last year. The result is true parallelism of the frame. Which will give our customers the best and straightest cuts with the longest bearing life possible. From 4x4-12x50 machines in accuracy not known by this market segment. Our newest capability is machining 13'x60'.
If Matt is using this profile he is one of the OGs of Plasma. If not then a technician. We make the worlds fastest and largest CNC plasma tables up to 10x40. www.StarLabCNC.com :Like Check out our Facebook page where we update frequently. https://m.facebook.com/StarLabcnc/
BTA Plasma
Re: Precision milled frames
martyy
Post by martyy »
I wasnt sure on what some of what you said means, but I dont have to be as long as you are. :-) Looks like some serious high quality work there. I always enjoying see the fruits of peoples labors. Thanks for sharing.
BTA Plasma
Thank you Marty. Basically we are cutting the frames so they are straight and true. Something unique in the industry with top industrial quality at an entry level price.
weldguy
Post by weldguy »
Very nice, don't see that in this price range very often :Like :Like
These look really nice! Perhaps you could share a few photos of your production process showing this bridge machining process in action.
BTA Plasma
Here is a video of part of our process.
ben de lappe
Post by ben de lappe »
Back in the day (89-93) I was in the usaf as an aircraft metals technology specialist and it was all manual machining. If I had produced sparks like that while cutting I'd likely have hit the E stop immediately and the floor right after. :HaHa Machining technology has sure advanced. I didn't know this bridge milling was a thing so thanks for the video. Concerning the table it does appear to be high quality indeed. :Like
SegoMan DeSigns
Post by SegoMan DeSigns »
You and Kronos Robotics are the only 2 companies I know that do this :Like :Like :Like
I slotted my rail mounting bracket's to allow for up / down - in /out movement then pulled wire to run my dial indicator against. I ended up at the + / - 0.003 in a 15' run..
weldguy
Post by weldguy »
Very impressive! Any company that does this for a plasma table in that price range you can bet puts that kind of love in other aspects of the machine as well :Like :Like
Return to “Star-Lab CNC Forum”
