Radius gauges?
Scratch
Radius gauges?
Post by Scratch »
I’m looking for ideas on what you guys use for radius gauges. When building stuff, I often need to trace a circle of some sort for some reason. I look around and try paint cans, buckets, cups etc. trying to find the right one. Other than just cutting a bunch of donuts (which would have two sizes on each one) does anyone here have a good solution or product they’ve found, like something adjustable maybe?
I’d like something from about 1/2” to 10”
djreiswig
Re: Radius gauges?
Post by djreiswig »
Compass?
ROKCRLER
Re: Radius gauges?
Post by ROKCRLER »
Scratch, have you seen this? Slight modifications and you have whatever circle you want.
https://www.swagoffroad.com/products/sw ... cle-cutter.
I bought one back before i got my table.
4x8 Dynatorch
PM85
~Mo~
weldguy
Re: Radius gauges?
Post by weldguy »
I 2nd the compass. Bought a large one on Amazon for around $15 and I find it very helpful. I too used to try and locate different diameter paint cans, rolls of tape, etc.
djreiswig
Re: Radius gauges?
Post by djreiswig »
weldguy
Re: Radius gauges?
Post by weldguy »
Great idea above from djreiswig :Like
Re: Radius gauges?
ROKCRLER wrote: Wed Aug 09, 2023 9:36 pm Scratch, have you seen this? Slight modifications and you have whatever circle you want.
Thanks Mo! I also bought one from Swag back before I had my table, and still haven't used it. But I do sometimes use one of several compasses I have to draw circles or circular segments onto poster board or cardboard to make templates.
Re: Radius gauges?
djreiswig wrote: Wed Aug 09, 2023 10:45 pm Screenshot_20230809-214507.png
Djreiswig - that is a nice looking diy compass you have there! I have something similar store bought. I don't remember where I got it, but it looks similar to this one.
Re: Radius gauges?
weldguy wrote: Wed Aug 09, 2023 10:26 pm I 2nd the compass. Bought a large one on Amazon for around $15 and I find it very helpful. I too used to try and locate different diameter paint cans, rolls of tape, etc.
Weldguy - in the past I too have used paint cans, tape rolls, welding bottle caps, weigh lifting weights (the round ones with a hole in the middle), or anything else I could find laying around the shop that was close to the size I needed. Sometimes I would cheat a little bit by moving the can, etc. to make a slightly larger circle. Another easy, pretty quick, and accurate method would be to use a sharpie/pencil attachment on the cnc plasma table and simply draw the size (or sizes) of circles you need on cardboard, paper, etc.
Re: Radius gauges?
I could see where having a bunch of pre-cut "donuts" might be handy as well. Something like these plywood donuts, or maybe cut some similar from sheet metal on the cnc. I might also be tempted to cut some from 1/8" Masonite (hardboard) on my cnc router.
Re: Radius gauges?
Or maybe something like this cut from 14 ga. or thicker.
circle template.dxf
Scratch
Re: Radius gauges?
Post by Scratch »
Thanks all, a bunch of great ideas you have. If anyone has any others please post them!
Re: Radius gauges?
David that drawing is slick, you being a tool manufacturer start marketing them :Yay Really only need a semi circle. :Like
AREA
Re: Radius gauges?
Post by AREA »
Great ideas here. Gotta get me a big compass.
DIY 2x2 table
Everlast 82i
Joe Jones
Re: Radius gauges?
Post by Joe Jones »
djreiswig wrote: Wed Aug 09, 2023 8:08 pmCompass?
Yep! OLD SCHOOL! :lol:
PlasmaCam 4x4 and 5x10 w/Upgrades
X-TOOL
(14) LASERS
(2) Apparel Printers
(1) MetalFab Machine
LaserPecker 1 PRO, LP-2, LP-4 +
50 Watt GALVO fiber laser
1,000 Watt 4x8 Fiber Laser
SwiftSHAPE machine
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
Bernardo Mach 55 TON Iron Worker
Grizzly G0792 - Roll Bender
Langmuir MR-1
Re: Radius gauges?
acourtjester wrote: Thu Aug 10, 2023 9:26 am David that drawing is slick, you being a tool manufacturer start marketing them :Yay Really only need a semi circle. :Like
Thanks Tom! I would be more comfortable working with the complete circle so that once I have the center established and aligned, I don't chance any misalignment as I rotate/reposition the template. It is easy enough to fill in the gaps in the drawn circle left by the spokes in the template. If you cut one, please show us your finished result - either cnc plasma cut or cnc router. I'm surprised I couldn't fine one like this already commercially available.
ROKCRLER
Re: Radius gauges?
Post by ROKCRLER »
Thanks David!
cuts great and takes the place of most all the random crap i look for when looking for radius'
I hit it quickly with a wire cup, still needs cleaning up. 16ga, 350ipm 45a
4x8 Dynatorch
PM85
~Mo~
Re: Radius gauges?
ROKCRLER wrote: Thu Aug 10, 2023 8:27 pm Thanks David!
Mo - thanks for posting that! It looks just like had envisioned. I could also see where it might be handy to have one for circles in between - say 1.5", 2.5", 3.5", etc. Maybe I'll draw up one like that as well.
ROKCRLER
Re: Radius gauges?
Post by ROKCRLER »
The in-betweens would be good, but not necessary i don't think. These can be fudged up to make the needed radius and lines extended.
I want to engrave the sizes on the next one for reference, but this killed the coffee lid, roll of tape, bottom of spray can, dog bowl.... all of it.
Its one of those, why didn't I do this sooner....Thanks again. :beer:
4x8 Dynatorch
PM85
~Mo~
ROKCRLER
Re: Radius gauges?
Post by ROKCRLER »
Or... half and half?
4x8 Dynatorch
PM85
~Mo~
Re: Radius gauges?
ROKCRLER wrote: Thu Aug 10, 2023 8:39 pm The in-betweens would be good, but not necessary i don't think. These can be fudged up to make the needed radius and lines extended.
Mo - you are quite welcome! Here is the file with the sizes added for engraving.
circle template with sizes.dxf
circle template with sizes.svg
Joe Jones
Re: Radius gauges?
Post by Joe Jones »
adbuch wrote: Thu Aug 10, 2023 9:07 pm
Did you allow for kerf width?
X-TOOL
(14) LASERS
SwiftSHAPE machine
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
Langmuir MR-1
ROKCRLER
Re: Radius gauges?
Post by ROKCRLER »
Joe Jones wrote: Thu Aug 10, 2023 10:00 pm
That's adjusted in sheetcam for me.
Drawing dimensions matched cut dimensions for me.
4x8 Dynatorch
PM85
~Mo~
tinspark
Re: Radius gauges?
Post by tinspark »
Scratch wrote: Thu Aug 10, 2023 9:10 am Thanks all, a bunch of great ideas you have. If anyone has any others please post them!
Here is one that Hypertherm makes.
Honestly we always made our own circle cutters by simply cutting a hole in a given plate large enough so that the torch nozzle slipped through and duct taped the torch tight to it then had a sliding coupling with a hole and a nut welded on with a wing nut to tighten it to whatever radius size was needed. the coupling also had a short sharpened tip to locate the center of the deaired radius. Very similar to the Hypertherm $150.00 jobber as depicted in the attached picture. But cost almost nothing. Mine is 30 years old and still works great. Also have one with a shaft coupling welded to it for my cutting torch,, But honestly since I purchased my cnc several years ago, most of my applications are doable on my cnc machine.
This one from Hypertherm looks real nice though
Edit: but after reexamining your question I think you were referring to drawing a circle not cutting one. so.......
Beam compass for me as well for drawing circles..
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Re: Radius gauges?
ROKCRLER wrote: Thu Aug 10, 2023 10:04 pm
Kerf width is compensated for with the cam portion of the process. In Design Edge, it would be adjusted under "Settings, Offset/Convert". In SheetCam, it would be adjusted in the "Jet Tool" tab. For engraving the numbers, I would normally set my kerf width to zero and cut "On Path" ("Same as source" for DE users).
