Inkscape Manual Trace method
I use Inkscape to do many traces to make DXF/SVG files to convert to G-code. Here is a process for manual tracing (Bezier tool) and node manipulation I did not know about. I have been using the node handles (round bubbles) to reshape the path, this is better with more control on the path lines. Attached is the video and the main points in the tracing process. The arrow cursor changes to a small x when on the line for moving it. An reducing the stroke to zero makes the line as small as it can be for clearer tracing, along with the Opacity value. :Like
node marker.jpg (29.51 KiB) Viewed 4801 times
node marker zero.jpg (40.73 KiB) Viewed 4801 times
node Opacity.jpg (24.68 KiB) Viewed 4801 times
Re: Manual Trace method
:Like :Like :Like
Dirtmotor
Post by Dirtmotor »
:Like :Like :Like
Thanks for that Tom. I use have used the bezier tool in Corel for years for the same purpose. I find that when the trace is done it can look and little "choppy" so I use the reduce nodes function to reduce the node points from the bezier tool and smooth out the lines. Does Inkscape have a similar function to accomplish this that you know of?
Dirtmotor
Re: Inkscape Manual Trace method
Post by Dirtmotor »
I use the simplify nodes option , sometimes it takes too many though .
Thanks Dirtmotor, I will look for the simplify nodes function. I know in Corels reduce nodes you can choose a value between 1-100 and the higher you go the more nodes it removes and the more your original curve may distort so I play with that value to get it with minimal nodes and still maintain the same arc.
Return to “Inkscape”
