This ides showed up on a welder site I go to.
While my plasma table has a water table I do not keep it full since I do a lot of cutting with the pipe cutting attachment. To me there is no reason to keep introduce a bunch of water and humidity to the shop.
While I was at Fabtech, I saw that one of the large tables made a miniature water table. I thought this was a great idea for when I want to cut on a small sheet of material.
I can put a hose on the outlet and drain it into a 5 gallon bucket.
This mini table is 24x36x2.5. That is plenty big enough for me to cut on scraps without filling up my entire 48x96 table.
Mini water table
Mini water table
Re: Mini water table
That's a great idea Tom. I had the same issue, just don't use my table like I used to and wasn't worth the time and expense of keeping a large table full and fresh. I ended up doing a downdraft setup instead but in the winter it sucks the heat our of my shop so this would be a great solution to that. Thanks for the idea!
DIY 2x2 table
Everlast 82i
Everlast 82i
- edclayton1
That looks like a great idea. Thanks for sharing the idea and the pictures.
Home Built 4 * 8 table
Bladerunner
Miller Syncrowave 250 TIG welder
Miller 211 Wirefeed Welder
Bridgeport Mill
Jet 13 * 40 Lathe
Hypertherm Powermax 65
80 gal 2 stage 175 PSI Emax air Compressor
Bladerunner
Bridgeport Mill
Jet 13 * 40 Lathe
- East German
The height wouldn't be enough for me, but it's a good idea!
Peter
Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
