Help With Monogram Letter
hselcer
Post by hselcer »
I can not for the life of figure out how to fit and combine the words and numbers in the middle to work. Please help!
MONOGRAM LETTERS.pcm
rdj357
Re: Help With Monogram Letter
Post by rdj357 »
Assuming you have DesignEdge with Advanced Design:
Draw a rectangle the width you want the letters to be. Draw it tall enough that it overlaps both top and bottom by 1/8 inch or so. Select the text and use the Fit to Path tool (Ctrl-V) and click on that rectangle. It doesn't mater which option you choose, parallel or uniform is what I usually use. This will make the text fit that width and height. Delete the rectangle and make sure the text does in fact overlap OK for each letter. Smooth it all (select and press Ctrl-H then type .002 and press enter. This will clean up any stray nodes. Select it all and press Ctrl-B to Combine it to a single piece.
If there is an error or a problem, you may have a problem somewhere else on the letter. Before combining, detect intersections and fix any that aren't where the letters overlap.
Robert Johnson
PlasmaCAM GURU & Instructor
hselcer
Post by hselcer »
AWESOME! Thank you so much!
rdj357
Post by rdj357 »
No problem, any time!
Robert Johnson
I used a different method. I believe that Robert's method is more efficient.
Robert - I tried your method with and without using the Smooth tool. Why does the Combine tool produce a bad result if the drawing is not smoothed first? It has the same number of intersections before and after smoothing (using "D"). Thanks!
Joe Jones
Post by Joe Jones »
hselcer wrote: Fri Dec 15, 2023 10:48 am I can not for the life of figure out how to fit and combine the words and numbers in the middle to work. Please help!
Where did you find these art files? They are a MESS!
Robert - thanks for your reply!
