Re open a .gm file into Torchmate?
442weld
Post by 442weld »
Is there a way to re open a .gm file into the torchmate program?
I made a file, loaded it into the plasma but realized I needed to tweak the program a little bit can’t figure out how to re open that file into the torchmate program.
kicktillmonday
Re: Re open .gm file?
Post by kicktillmonday »
What program generates your .gm files? Are you able to attach one of these files in a reply here? I am not familiar with .gm.
DIY 4x8 table
Powermax 65
442weld
Post by 442weld »
Torchmate program
442weld wrote: Tue Feb 06, 2024 11:42 am Is there a way to re open a .gm file into the torchmate program?
Rename the .gm to .nc, then you can import the file into TM Cad and it will show up as a line drawing. You will need to delete the lead-in/outs as well as the objects will be slightly bigger or smaller depending on the kerf compensation.
kicktillmonday
adbuch wrote: Tue Feb 06, 2024 5:18 pm
Oh man David, thats a sweet deal! Had no idea. Hope that works out for him.
DIY 4x8 table
Powermax 65
Burton Welding
Post by Burton Welding »
Extremely helpful. thank you so much!
Burton Welding wrote: Fri Sep 13, 2024 9:15 am Extremely helpful. thank you so much!
:Like :Like :Like
Return to “Torchmate Forum”
