welding fixture table top
All topics related to mig welding, tig welding, spot welders, flame cutting, etc.
Dirtmotor
Post by Dirtmotor »
Finished up the fixture/welding table top ! Used 5/8 steel cut it out on plasma table . Its 32 x 44 with 77 5/8 holes on 4 inch centers , I sealed edges of plate with masons flex self stick flashing then soaked in 50/50 muriatic over night to loosen mill scale .,It rinsed almost clean then flap wheeled . Tacked 1 1/2 square tube on back and set it on shop table (with tractor) . So far its working good still making some clamps and other tools for it .
DieselFumes
Re: welding fixture table top
Post by DieselFumes »
Great looking fixture table. Have always wanted one but I can't afford it so would have to do something like that. Pretty slick :Like
Tracker CNC 4x4
tinspark
Post by tinspark »
Looks pretty sweet. Post up pics of the clamps that you come up with>
I was thinking of purchasing a mag drill to make one. Since I didn’t want to chance burning one on my 45xp plasma cutter. But a little thinner , maybe .375 or even .25”
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Dirtmotor
Post by Dirtmotor »
tinspark wrote: Fri Mar 29, 2024 5:17 pm Looks pretty sweet. Post up pics of the clamps that you come up with>
I did borrow a mag drill , and used a annular cutter, worked great ! Bit was cutting the same on last hole as it did on the first .
Dirtmotor
Post by Dirtmotor »
This is first clamp , made it out of a couple 5/8 bolts , a 3/4 nut ,3-1/2 nuts and some 1/2 all thread and one 5/8 id bore shaft collar,it was pretty easy , swivel foot is a 1/2 inch nut with all but one thread drilled out and a washer , had to grind small ball on end of all thread leaving a couple of threads on sides , then welded nut to washer with thread turned up, screwed it on to ball and works great , does not fall off .
That's a great looking fixture plate. How flat is it? Nice job!
Dirtmotor
Post by Dirtmotor »
adbuch wrote: Sat Mar 30, 2024 10:13 pm That's a great looking fixture plate. How flat is it? Nice job!
Not perfectly flat but close enough , its as good as you can
get without surface grinding .
Don't know who's quote this is but I like it !
“The bitterness of poor quality remains long after the sweetness of low price is forgotten”
Buy the best tools you can afford.. Learn to use them to the best of your ability.. and take care of them...
Neat to see other's DIY tools never know when one my strike your fancy for you to copy or adapt to fit your shop.
kicktillmonday
Post by kicktillmonday »
Super cool, man would love to do something like this this one day.
DIY 4x8 table
Powermax 65
tinspark
Post by tinspark »
Dirtmotor wrote: Sat Mar 30, 2024 9:04 pm 1000001145.jpgThis is first clamp , made it out of a couple 5/8 bolts , a 3/4 nut ,3-1/2 nuts and some 1/2 all thread and one 5/8 id bore shaft collar,it was pretty easy , swivel foot is a 1/2 inch nut with all but one thread drilled out and a washer , had to grind small ball on end of all thread leaving a couple of threads on sides , then welded nut to washer with thread turned up, screwed it on to ball and works great , does not fall off .
Looks Great.
I saw your clamp setup and it made me wonder why you chose the oversized slider nut instead of another set/shaft collar above the lower stop set collar. I assume that the slop is needed in the oversized slider nut so that it grabs instead of pulling the pin out due to too much vertical lift without enough bind instead of a lateral bind that might occur with the oversized nut? Or........? hmmmmm
I haven't made a fixture clamp before, but am I close??
Doug,
Hypertherm 45XP-
tinspark wrote: Tue Apr 02, 2024 12:16 am
Doug - I think you are correct in your assumption. Here are several of mine. Part of the force applied at 1 is transferred to 2, causing the pin to bind in the table hole and prevent lift.
Dirtmotor
Post by Dirtmotor »
Yep need the slop to lock in , the horizontal rod is canted down slightly as well as the nut for all thread, so force is aprox. straight down .
Dirtmotor wrote: Tue Apr 02, 2024 8:18 am Yep need the slop to lock in , the horizontal rod is canted down slightly as well as the nut for all thread, so force is aprox. straight down .
:Like :Like :Like
tinspark
Post by tinspark »
adbuch wrote: Tue Apr 02, 2024 2:41 am
:Like :Like :Like :Like
Doug,
Hypertherm 45XP-
tinspark
Post by tinspark »
:Like :Like :Like
Doug,
Hypertherm 45XP-
Dirtmotor
Post by Dirtmotor »
This is my version of a bandsaw holder , works great !
Now that's slick for a saw mount, what do you do for the trigger hold down, Velcro??
I assume you have it mounted for cutting and not just to hold it in between use? In any case, a nice looking bracket.
Dirtmotor
Post by Dirtmotor »
acourtjester wrote: Sun May 12, 2024 4:19 pm Now that's slick for a saw mount, what do you do for the trigger hold down, Velcro??
Thanks , velcro would work , for now using a wood block , will get a foot pedal for it eventually .
Dirtmotor
Post by Dirtmotor »
adbuch wrote: Sun May 12, 2024 7:39 pm I assume you have it mounted for cutting and not just to hold it in between use? In any case, a nice looking bracket.
You are correct . Wanted to have a way to cut small stock , the horizontal bandsaw is too big for somethings .
Dirtmotor wrote: Sun May 12, 2024 8:22 pm
:Like :Like :Like
I used a lever setup to hold the trigger down, with a quick release when done cutting. :HaHa :HaHa
Dirtmotor
Post by Dirtmotor »
acourtjester wrote: Mon May 13, 2024 9:18 am I used a lever setup to hold the trigger down, with a quick release when done cutting. :HaHa :HaHa
Wow! that is beautiful , It looks like your band saw is permanently mounted ? I was trying to make it easy to remove for hand held use .Do you have it plugged into a foot switch ?
No foot switch and it was a full permanently mounted saw, I made 2 one for me and my daughter. They can be used either horizontal or vertically.
Very nice Tom! You say "Band saw type 1" and "Band saw type 2". What is the difference between the two types? Do you have a set of plans you would care to share for your setup?
Return to “Mig Welders, Tig Welders, Spot Welders”
