mach3 jog flyout menu
The tab key doesn't produce the jog flyout menu.. Is there another way to adjust the jog speed ?
Re: mach3 jog flyout menu
I am not a Mach 3 user but I suspect that from one of the drop down menus at the top of your screen you should be able to access the window your TAB key should be opening for you.
The tab key opens a screen in the screen set. If you don't have the correct screen, it won't show up. Did it ever work?
