Thought i would show my water mist system. Originally I built the table with a fan for downdraft which didn’t work very well, the fan wasn’t strong enough and when there were lots of gaps from cutting there was next to no suction. Instead of rebuilding and converting to a water table or upgrading to a larger fan i added a water mist sprayer.
This is a very simple system of water pump, mist nozzle used for milling machine and an air solenoid.
My pump is a little oversized so i added a controlled bleed off, which is just a t and valve returning water back into the drum.
Sheetcam path rules are used to turn on and off the pump/ air solenoid everytime the plasma arcs
This has resulted in drastically reduced smoke and dust with the added benefit of cooling the steel. Also there is a reduction of dross on stainless cuts
Also on rapids between cuts i am raising the torch a little higher than normal to allow the post flow to dry the plasma nozzle
Hopefully this helps someone else out
Alternative to water or down draft
Re: Alternative to water or down draft
That's super cool! What a great idea, thanks for posting your setup.
