This just popped up on one of the Plasmacam Facebook groups. It looks to be a super deal.
https://www.facebook.com/groups/PlasmaC ... ONOLOGICAL
"Hey fellas, I upgraded to two fiber laser tables last year so I’m selling all of my Plasmacam tables and parts at once. Here’s what you get at minimum, I have a ton of extra parts etc as well that will go in the deal.
7 controllers (I had a spare for each table)
3 separate licenses with advanced height control and 5x10 table size.
Any and all parts on each table, gantries, motors, cables, etc
2 Hypertherm power max 45xp,
3-4 machine torches, whatever I have. I used the fine cut 30amp consumables for the finest cuts possible cutting 14 gauge on 3 tables for hours every day. Beautiful cuts.
You can have all 3 used steel tables if you want them as well, otherwise I’ll scrap them later. 2 cut up to 5x10, one cuts 4x8, and I have the rails and gantry etc to build a 4th table, you can have as well.
Over $1000 in nozzles, electrodes, etc.
3 tables were running when we switched to laser so minimum 6 working motors, and a box of approx 10 or more motors that some work, some do not. 12’ cables, drag chains, etc.
Details on the controllers, 2 are brand new inside, still have repair tags, 2 were ran for maybe 3 months on brand new inside boards, 1 more ran 6 months, 2 need repair.
Again, you can have it all including the tables if you want them. $16k for all. Bossier City, La. Message if interested. We can load the tables with fork lift, but you will have to cut the legs off of two tables to remove from their room so you’ll need a few guys and some grinder cutting wheels to get it out, then weld and level at your place. I custom built each table so they’re super strong and heavy."
Plasmacam Tables for Sale
Re: Plasmacam Tables for Sale
Where's Joe?
- Joe Jones
I know about it. I will pass.
