Oxygen tank freezing
Blackhat4life38
Post by Blackhat4life38 »
Hello, we run a Hypertherm 260xd with an Alltra bed and 60-gallon oxygen tank. We constantly have issues with the oxygen tank freezing up, anyone have suggestions on preventing this?
weldguy
Re: Oxygen tank freezing
Post by weldguy »
Whats the ambient temperature in the work area where the equipment is?
Blackhat4life38
About 60 to 70 degrees
Blackhat4life38
When cutting one inch material we always have issues with the regulator and tank freezing. We are at the point we leave a heat lamp over it.
weldguy
Post by weldguy »
Is it the tank freezing up or the regulator? If it is the regulator you may want to look into a higher flow capacity regulator. Flowing too much oxygen through too small of a regulator can cause it to freeze up.
Blackhat4life38
Its the tank mainly
SegoMan DeSigns
Post by SegoMan DeSigns »
They make a tank heating blanket for cold climates, the ones I've seen are pricey but so is waiting on the tank to unfreeze to resume cutting.
BTA Plasma
Post by BTA Plasma »
For those that use liquid form for cutting you need to integrate a vaporizer or you will always have freezing. There are some places in the USA that simply store outside but the atmosphere inside the tank will always raise in temperature and your blow off valve will activate more...even more as you use your bulk liquid and there is more room in the tank. Ask your provider for a vaporizer. They are relatively cheap ($2-7K)
-Matt
If Matt is using this profile he is one of the OGs of Plasma. If not then a technician. We make the worlds fastest and largest CNC plasma tables up to 10x40. www.StarLabCNC.com :Like Check out our Facebook page where we update frequently. https://m.facebook.com/StarLabcnc/
SegoMan DeSigns
BTA Plasma wrote: Fri Oct 11, 2024 10:57 am For those that use liquid form for cutting you need to integrate a vaporizer or you will always have freezing. There are some places in the USA that simply store outside but the atmosphere inside the tank will always raise in temperature and your blow off valve will activate more...even more as you use your bulk liquid and there is more room in the tank. Ask your provider for a vaporizer. They are relatively cheap ($2-7K)
-Matt
Matt,
Thanks for posting that information, you would think the gas supplier would tell the customers that.
