Jeep Key Holder
Jeep Key Holder
Attached is a Jeep Keyholder design. The most difficult part is bending the bottom tabs into the keyholder design.
- Joe Jones
Re: Jeep Key Holder
That is a cool design
Re: Jeep Key Holder
Super cool, I know a few Jeep nuts who would love one. Thanks for sharing dbrub2
Tracker CNC 4x4
Re: Jeep Key Holder
Nice! Thanks for sharing. I have a neighbor who's been bitten (kinda hard, seemingly) by the Jeep bug.
Shop-built 5x10 table powered by QtPlasmaC
Hypertherm PM 85 machine torch
Lincoln PowerMig 255C
Lincoln Square Wave Tig 255
Ermak SpeedBend Pro
Ermak SpeedBend Pro
- Rem300wm
Re: Jeep Key Holder
Hello to All
Thank you for sharing the file is very nice.
Here is in DXF
Here is in DXF
Re: Jeep Key Holder
Thanks for converting the svg to dxf. I opened you dxf with Inkscape and it looks fine.Rem300wm wrote: Sat Nov 23, 2024 3:48 am Hello to All
Here is in DXF
Jeep Key holder.dxf
Re: Jeep Key Holder
i found the best way to bend the tabs is clamp them in a vise with a small pipe and bend around the pipe
- SegoMan DeSigns
Re: Jeep Key Holder
I do a similar system but use flat stock the thickness needed then I sandwich the key holder in between it and the edge of the welding table. Get out the hammer and bop away, getting both bends without having to retool.
Re: Jeep Key Holder
The problem in bending is creating the compound bend (see circled area in pic) that provides a key-ring standoff which keeps the keys from rubbing against the wall leaving scratches.
Re: Jeep Key Holder
Re: Jeep Key Holder
Dbrub2 - I do like your idea for the keyholder. I was thinking about using the same approach for a Porsche keyholder. This is what I have come up with so far. I need to get rid of some of the smaller details to make it more "cut friendly".dbrub2 wrote: Fri Oct 18, 2024 9:06 am Attached is a Jeep Keyholder design. The most difficult part is bending the bottom tabs into the keyholder design.
Re: Jeep Key Holder
Your bending process is the approach I use and the first two bends are pretty simple but holding the rod while forming the circular bend and having all 5 circles match was more time consuming than I wanted. Finally machined a couple aluminum blocks with circular cutout that held rod against welding table and when clamped down allowed me to bend the circle.
Your mod to make a Porsche key holder is great. Maybe we should make a blank and others can add the vehicle of choice!
Re: Jeep Key Holder
Thanks dbrub2! Here are some blanks. The size can be scaled to whatever the user wants.
Re: Jeep Key Holder
I posted my finished Porsche Keyholder at a new thread here.
https://plasmaspider.com/viewtopic.php?p=242686#p242686
Re: Jeep Key Holder
Nice!! Thanks for the blank key holder.
