Ran across this and always wanted to cut similar but havent found it.
Vine panels.
Does anyone have a file like this? Vines?
- Complete_Loser
You want it done cheap and fast, it wont be right.
You want it done right and fast, it wont be cheap.
You want it done right and cheap.., come back in a year..
Re: Does anyone have a file like this? Vines?
There is this viewtopic.php?t=31044
Copy and paste the string below into Google address bar and you will find others
site:plasmaspider.com vines
- tinspark
I found the same one that Plasmanewbie did.
here are a few others that are not in a pre determined frame size, and could easily be modified into whatever frame size that you require
https://plasmaspider.com/viewtopic.php? ... ne#p151311
https://plasmaspider.com/viewtopic.php? ... ne#p158415
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Hypertherm 45XP-
- tinspark
Also, I see those at our local ornamantal iron suppliers stores
You should be able to purcase something like that there.
Most have catalogues that can probably get you the exact ones as you have depicted.
And they might even be cheaper than the materials to make something similar.
They are typically cast aluminum or pot metal with weld nuts cast aat strategic locations in teh part for fastening. But honestly the CNC cut ones are way nicer IMO!
I removed my aniquated ones and replaced with CNC parts
Doug,
Hypertherm 45XP-
Hypertherm 45XP-
- Complete_Loser
Nice! Thanks a bunch.
