FlashForge Creator 3 vs. Bambu Labs PS1
Topics related to 3d printers and 3d printed plasma table accessories.
I have a recent project where I want to create some various sized frames for the Shaper Trace. I have considered several different methods, including plasma cutting, printing on paper, cnc router, and 3D printing. I measured and drew up the original frame using Fusion 360 and created stl files for 3D printing to see how that would work.
My existing 3D printer is a FlashForge Creator 3 with dual independent extruders - so it has the ability to print in two different colors. I imported the stl files into the FlashPrint slicer to see how long the print would be. It turns out that the print time is around 8 hours. That seems like a long print time to me.
For comparison, I used the Bambu Labs slicer for the Bambu Labs PS1 3D printer (single extruder with multi color capability) to see how long it would take to print. To my surprise - the print time as only around 2 hours.
The Bambu Labs PS1 is currently on sale - so I went ahead and ordered one to check it out.
I have other multi-color projects in the "pipeline", so I think this new printer will make a nice addition to the shop.
kn612
Re: FlashForge Creator 3 vs. Bambu Labs PS1
Post by kn612 »
You'll want to print this for the AMS:
https://www.printables.com/model/542244 ... buffer-fix
https://www.printables.com/model/587067 ... -ptfe-tube
The filament will often fail to feed without it. Other than that I've experienced zero issues with mine. Gave away my Ender 3 after getting a P1S. Print speed and quality is incredible.
kn612 wrote: Sun Jan 12, 2025 10:31 am You'll want to print this for the AMS:
Thanks for that information! Will I need one of these for each color? Also - it this something that Bambu Labs sells, is it available as a finished product on the aftermarket, or is it only available by printing it?
kn612
Post by kn612 »
You'll only need one. It straightens out the ptfe tube that goes into the ams buffer that is on the back of the printer. There are quite a few different solutions for it that others have designed and uploaded stls for. The one I linked is what Ive been using and haven't had a fail to feed error since.
kn612 wrote: Sun Jan 12, 2025 8:01 pm You'll only need one. It straightens out the ptfe tube that goes into the ams buffer that is on the back of the printer. There are quite a few different solutions for it that others have designed and uploaded stls for. The one I linked is what Ive been using and haven't had a fail to feed error since.
OK - thanks!
It says that one of these is the "Bambu AMS filament buffer fix" and the other is the "Bambu Lab Curved Holder for left AMS Hub PTFE Tube - Remixed Short". Do I need both of these?
kn612
Post by kn612 »
The buffer fix will work on its on, the curved holder add on just helps it a little more.
kn612 wrote: Sun Jan 12, 2025 9:02 pm The buffer fix will work on its on, the curved holder add on just helps it a little more.
:Like :Like :Like
Thanks - I will print all of the parts.
Return to “3D Printers & Printed Accessories”
