Tool box for field cultivator
My boss needed a box to bolt on his vertical tillage tool that can hold several sweeps along with the tool to replace them. I made this one to straddle a 6" beam near the front hitch. It attaches via 7" carriage bolts thru the bottom of the box and a strap at the bottom. I hand drilled a couple of 3/8" holes thru the side of the top and to corner of the box to hinge it. Hope someone can use it. Done in Plasmacam DesighEdge
K D Metal Werks
PlasmaCam DHC2
Hypertherm Power Max 45
Hobart Handler 190 Mig
Niagara 3"x 36" Slip Roll 14ga
Driess/ Krumph 4' box & pan brake 16ga
Hossfeld #2 Bender Ridgid 700 threader
Pexto 137-1 16ga. Stomp Shear
MADE IN USA
PlasmaCam DHC2
MADE IN USA
Re: Tool box for field cultivator
Thanks for the design this could be used for many doffernt applications
Here is my finished product
K D Metal Werks
PlasmaCam DHC2
MADE IN USA
PlasmaCam DHC2
MADE IN USA
Excellent result! And it came out even better since you cut it on your Plasmacam table.
Turned out great, nice to be able to make this kind of thing on your own
