EMT pictures frame SVG
You may have to resize the center. The center was a bit big. Sized for 8.5 x 11. We tried alcohol metal ink and then clear coated the frame.
Re: EMT pictures frame
Looks great and I have someone I make one of these for. Thank you! Had to convert to dxf for me to use so I hope you don;t mind I posted it below for anyone else who needs a dxf.
Re: EMT pictures frame SVG
Great. Appreciate the file format. Glad you can use it
Make sure you check the center size. It could be a bit smaller
Looks great. I am sure there are some EMT's out there who would love this. Thanks for sharing
K D Metal Werks
PlasmaCam DHC2
Hypertherm Power Max 45
Hobart Handler 190 Mig
Niagara 3"x 36" Slip Roll 14ga
Driess/ Krumph 4' box & pan brake 16ga
Hossfeld #2 Bender Ridgid 700 threader
Pexto 137-1 16ga. Stomp Shear
MADE IN USA
PlasmaCam DHC2
MADE IN USA
Very nicely done! I love that great looking finish. Thanks for sharing your work.
Thanks for the heads up, I will be sure check that outellenmkling wrote: Tue Feb 25, 2025 1:51 pm Make sure you check the center size. It could be a bit smaller
