pierce time problem/ sheetcam /mach3
bob49
Post by bob49 »
I need some help from the plasma guru's- I'm running a diy table with mach 3,sheet cam and delta cad. TD cut master 82.
Here is my problem, when i go to cut parts with an internal cut and pierce point my torch actually moves before the pierce is completed. (lag time from when torch signal is sent to arc start) I'm not using THC or OK to move, but will soon.
I have played with pierce delay in sheet cam, but had little success , i have set delay as far as 4 seconds but it does not respond. Is it possible to set a dwell time for the torch to move? any input would be helpful thanks Bob
bob49
Re: pierce time problem/ sheetcam
Post by bob49 »
nobody loves me :( Bob
Eagle Mtn Metal Works
bob49 wrote:nobody loves me :( Bob
Hey bob49
Give it time somebody will help. Just may take a while for someone to see your post. Good luck.
Rod S in AZ
AnotherDano
Post by AnotherDano »
I loves ya, Bob.
But I run a PCam and have no idea how to help. :cry:
Dano Roberts
droberts@ironpequod.com
PlasmaCam DHC-2 v3.11
Hypertherm PowerMax-30
bob49
Post by bob49 »
I feel much better now! lol Bob
SignTorch Vector Art
Post by SignTorch Vector Art »
If you're inputting seconds in sheetcam then you might need to set dwell-time-in-seconds (by unchecking dwell-time-in-milliseconds) in mach3 under general-logic-configuration
Or just enter milliseconds in sheetcam i.e. enter 1000 for 1 second dwell
bob49
Post by bob49 »
Thanks guys....that's why you are the plasma guru's - I would of never found that .... Bob
