TD 52 and Sound logic wiring
- Zippo
- 4.5 Star Member
Just bought a new td 52 and was going to install my sound logic board on it, and i see they sorta hide the wires on this one. lol seems they would like you to put a cnc interface card on it, is anyone familiar with wiring around that feature running a type1 torch head so easy enough to get to the switch wires,work cable,and dont believe i will need my HECS on this one, but hunting the rest, have not got a call back from rep so figured check here as well
Re: TD 52 and Sound logic wiring
NOt sure what the hell a sound logic card is but here I Have some diagrams and placment of my parts on the TD 51
http://www.cnczone.com/forums/precision ... d_3x4.html
- Zippo
- 4.5 Star Member
this is the sound logic for THC. use it with my THC301d
Looks similiar in operation as mine.. from CandCNC... check out my link
- Zippo
- 4.5 Star Member
Well figured out the pins so if anyone gets a Therma Dymanic that has the automation interface hook- up on your J10 it is pins 1 & 3 for arc/ok to move and pins 6 & 8 for your switch , For your tip volts well it your work and elctrode1
