Candcnc dragon cut start up issue
- tentonjj
Just trying to get my machine going with the Mach 3 software. I have the dragon cut kit from candcnc. All of my motors have power from the box. The only thing that will not light up on the box is the charge pump light on the ubob panel. It says I may not have communication to the parallel port on the pc, but what the he'll does that mean? Also I cannot find the candcnc profile in the profile choices. Sorry if these are dumb questions. I knew I was gonna have problems like this. Any help would be great.
Jayson Johnson
JMJ Graphix
920-517-7122
JMJ Graphix
920-517-7122
Re: Candcnc dragon cut start up issue
Jayson,
Try here:
http://www.cnczone.com/forums/cnc_plasm ... _machines/
Tom Caudle aka torchhead (owner of CandCnc) lurks there and is always willing to help with his (and others) gear.
WSS
Try here:
WSS
- tentonjj
Thanks a bunchWSS wrote:Jayson,
Try here:
WSS
Jayson Johnson
JMJ Graphix
920-517-7122
JMJ Graphix
920-517-7122
- tentonjj
Ok so I don't know how but I figured it out. They all 4 move. But now it doesn't seem that the side motors move at the same time or at the same speed.
Jayson Johnson
JMJ Graphix
920-517-7122
JMJ Graphix
920-517-7122
While running Mech3, under the config menu, select "Slave Axis" From there select the motor you wish to slave, with the side Axis motor. In my case the side axis motor was Y and the Slave is Atentonjj wrote:Ok so I don't know how but I figured it out. They all 4 move. But now it doesn't seem that the side motors move at the same time or at the same speed.
- tentonjj
props to you.......thanks!!!!
Jayson Johnson
JMJ Graphix
920-517-7122
JMJ Graphix
920-517-7122
