Nice Deer Scene to Share!
FreeDXF.com
Post by FreeDXF.com »
Hello Everyone,
Here is a nice deer scene that I designed up today. The design work should be cut approximately 24" wide by 22" tall. Please post a picture to this thread if you get a chance to cut the design work out. Enjoy!
Sincerely,
FreeDXF.com
1-866-439-3543
Deer Animal Scene.dxf
mdoffroad
Re: Nice Deer Scene to Share!
Post by mdoffroad »
Nice Work!!!
bwgsmith
Post by bwgsmith »
Looks good thanks.
jasond
Post by jasond »
Very nice! Thanks!
FreeDXF.com
You are all very welcome for the design work =)
jhowie
Post by jhowie »
Thank you very much!
TotalPerformance
Post by TotalPerformance »
Wow, Very nice work! I am new to the cnc plasma world. I've only had my table up and running for about a week now. What thickness of steel do most people cut something like this out of? I of course now know I should have bought a Hypertherm for the fine cut ability. I have a Thermal Dynamics A80 and running a 30A tip I can't seem to save the small details on thin gauge material. I am using a water table and even with it touching material some of the fine details get too hot. I haven't tried this file yet. I need to learn how to modify the cut order to keep things from getting hot as well. Guess this should have been somewhere else. Sorry for the long post. Again, nice work.
hdfaster
Post by hdfaster »
Very nice, thank you for sharing.
FreeDXF.com
Welcome to the wonderful world of CNC Plasma cutting. The design work provided would be ideally cut from 1/16" or 1/8" mild steel. Your 30 amp tip should be capable of cutting the design work quite nicely with good results. As long as your cut width is .0625" or smaller you should be able to cut the design work perfectly the first time. Once you determine how to re-order the cut paths you should be able to minimize the heat build up within the design work. Good luck with your cutting! JH
Eagle Mtn Metal Works
Jason
Your work is always so nice. Thanks' for sharing.
Rod S in AZ
sbest1
Post by sbest1 »
Thanks again Jason! Love your files.
Great file, thanks! This truly is the best site.
FreeDXF.com
I would have to agree that this website is the best CNC plasma cutting resource on the internet. JH
AIRFLOWKID
Post by AIRFLOWKID »
Jason,
GREAT FILE JASON!
Thanks so much, Tim
Red Robin Creatives :ugeek:
alaska66
Post by alaska66 »
Your talent is only exceeded by your generousity. Thanks for sharing Jason.
34chev
Post by 34chev »
Thanks Jason, this will go great with the bear.
wishiwastorching
Post by wishiwastorching »
Thank you very much jason!
jim c
Post by jim c »
Thanks Jason, for another great file.
trucks1948
Post by trucks1948 »
Thanks Jason cuts nice.jim
FreeDXF.com
Thanks for all the supportive comments and for sharing the cut and finished design work. The cut design work turned out great! JH
jonn3y
Post by jonn3y »
What do you use to draw your pieces in? Ive been using illustrator but is there something better out there? Nice picture i was gonna try and add more detail to mine if that is ok??
*edit found out how to turn it into an Ai file thanks!*
ShaneP
Post by ShaneP »
Great file! Thank you for sharing.
Searchman
Post by Searchman »
Well done. Thanks for the share
