how can i tell number of cutting inches
trucks1948
Post by trucks1948 »
I am using Mach three and sheetcam and trying to figure out the number of cutting inches in various projects so i can get pricing figured out.I am drawing with coreldraw x5 .I am using an old practical table updated with candcnc DTHC.thanks Jim
4R8
Re: how can i tell number of cutting inches
Post by 4R8 »
G'day Jim.
Sheetcam makes this easy. Under the file menu there is "job report".
This gives cut time, pierces, cut inches, etc. All the info needed for the quote and more.
Hope that helps.
trucks1948
thank you! Hey i just tried it.It's so simple when you know what you are doing.Thanks again jim
agteacher
Post by agteacher »
Anybody know how to do this with the Torchmate CAD?
Randy Dobbins
Welding Teacher Humble ISD
jmsrbrt
Post by jmsrbrt »
agteacher wrote:Anybody know how to do this with the Torchmate CAD?
The cutting program will tell you the time it takes to cut the file, and you've set your inches per minute (IPM). 100 IPM for 5 minutes would be 500 inches. Unfortunately there is no way to get the pierces that I know of, unless you count the number of times the code G00 appears in your file. Bob.
Corel 12, Turbo Cad
TD Cutmaster 51
San Marcos, Texas
Return to “Mach3 & Mach4 CNC”
