As configured in mach3 floating head?
ctorres3120
Post by ctorres3120 »
Greetings ... I mount my plasma to a system of THC, but I'm going to have to put a floating head.
If anyone knows how to put the macro in Mach3, that G31 before cutting down to play and adjust the height materiar start, appreciate any help.
Carlos :D
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
Hypertherm PowerMax 1250
http://www.facebook.com/ctorresp?ref=tn_tnmn
JJsCustomDesigns
Re: As configured in mach3 floating head?
Post by JJsCustomDesigns »
i just seen your message on facebook. i did a quick google search and it led me to the machforums.
http://www.machsupport.com/forum/index. ... ic=17132.0
hope this helps.
PM me with details
ctorres3120
Thanks, JJ for your help, I will try this
Carlos :D
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
JJsCustomDesigns
No problemo.
PM me with details
JJsCustomDesigns
I even picked up a little info there. i always wondered why the plasma torch would touch off every cut and other times it wouldnt.
Using the G28.1 method and assuming the distance + the travel equals .250" NOTE: your Cam program will have a place for THAT setting
G28.1 Z.50 ' references the head down until it trips the switch
G92 Z0.000 'Sets that point to ZERO
G0 Z0.250 ' Moves the head UP the amount of the head travel + switch movement
G92 Z0.000 ' Sets that position to ZERO, that will be TOP of the material,
G0 Z.100 ' Move the head up to a clearance position
NOW you head is referenced to the TOM and you are ready to start a cut.
*Note that most CAMS rereference the TOM every so many inches of torch travel . If the setting is every 50" then the next torch start after the machine has cut 50" then it will ref the head before it cuts again."
PM me with details
Return to “Mach3 & Mach4 CNC”
