Line segments
Charlene
Line segments
Post by Charlene »
Why, when I open some files, do they open with a lot of little line segments? Why can't I fix it in corelDraw x5 using "Join Curves"? And, will it actually matter when I load it in Sheetcam or Mach?
I did a search on here already but couldn't find anything that worked. :?
Here is an example file:
sfx_cocker_ps.dxf
(209.61 KiB) Downloaded 135 times
sfx_cocker_ps.dxf
Thanks for any help you can give me.
MQUICK
Re: Line segments
Post by MQUICK »
I use plasmacam ( the old good one) and it joines them with no problem. I dont use the programs your using, so im no help there. If it helps this file is one line.
sfx_cocker2.dxf
(51.5 KiB) Downloaded 123 times
sfx_cocker2.dxf
Charlene
Re: Line segments
Post by Charlene »
Thank you MQUICK. That is very helpful.
If anyone out there can help me so that I can fix files myself, I would really appreciate it.
steelfx
Re: Line segments
Post by steelfx »
Charlene,
See if you can import this file into Corel. It should work. Not really sure why you'd import a DXF into a drawing
program. :?:
cocker_sfx_full_body.ai
ai & eps are the same.
(528.02 KiB) Downloaded 110 times
Charlene
Re: Line segments
Post by Charlene »
Thanks Bill. Not sure what you mean. I use Corel as the program that I create in or to make changes to other files in. I do have BobCAD but Corel was much easier for me to learn. The .ai file opens fine but it is now a detailed pic and is no longer a silhouette drawing. It is a great file and I will take it out to the shop computer and try it in BobCAD. I will update tomorrow. Thanks again.
steelfx
Re: Line segments
Post by steelfx »
Try this version...it's got all the edge nodes for modifying the file or adding text, etc.
The first one I uploaded wasn't "grouped", so it was likely not worth having. This one should be what you need to
use in Corel. In my drawing software, I can't import a DXF to modify it, so that's why I'm so confused.
I use BobCad v21 & XARA v7.
:oops: :D :oops:
cocker.ai
(40.71 KiB) Downloaded 109 times
cocker.ai
Charlene
Re: Line segments
Post by Charlene »
Thank you. That works. I opened it in Corel and then saved it as a dxf. Perfect. So from now on when I see the line segments I will open the file with bobCAD instead and then save it so that I can open it with Corel.
Also, I will eventually work at learning bobCAD! ;) :oops: :?:
steelfx
Re: Line segments
Post by steelfx »
:D
SignTorch Vector Art
Re: Line segments
Post by SignTorch Vector Art »
For node-join to work you have to select all the nodes,
After opening/importing
Double click the pick tool to select all objects
Hit combine
Double click the shape tool to select all nodes
Hit join-nodes
(in this case) Enter 40 in the Reduce-Nodes input
Charlene
Re: Line segments
Post by Charlene »
SignTorch Vector Art wrote:For node-join to work you have to select all the nodes,
Hit combine
Hit join-nodes
Thanks Gary. I was with you up until "Hit join-nodes". I don't seem to have that command. Is that what "join curves" is for me? I tried both "Join Curves" and the "Extend Curve to Close" button but both of these options causes it to jump over nodes. For instance, after joining curves there will be a line from node 1 to 2 & then 3 as well as from node 1 to 3. I hope that makes sense.
Re: Line segments
oh, yes I meant the Join-Curves Docker (left-below), which leaves 1493 nodes on 3 subpaths, then reduce-nodes by 40 leaves 171 nodes, with no apparent flaws (except one simple intersection did occur on the tail)
if I use the join-curve button (right-below), it leaves 1695 nodes on 5 subpaths, with some defects
if I don't combine first, then either method comes out very defective
(don't forget to stand on your head and do jumping jacks... :) )
corel join curves docker
Charlene
Re: Line segments
Post by Charlene »
Gary, I am sorry that I am just now responding... (I got stuck on my head! :lol: ) Thanks for the info, it worked perfect.
I am so glad that there are people like you on this forum willing to share your knowledge. Thanks again.
teknition1
Re: Line segments
Post by teknition1 »
Hit combine
Hit join-nodes
Thats solid gold right there! Thanks Gary! You should put out a small book that deals with working with Corel strictly for plasma. I would be the first in line of many to buy it!
Brad
