Powermax 65
Fine cut consumables
40 amps
325 ipm
75 volts
Water table
This was my first go with fine cut consumables and thin material. I am not too happy with the results. The first thing I noticed was the torch raising half way through cuts longer than an 1" ad the voltage would spike to 115<. The edges have a large positive bevel. Any help would be much appreciated.
Dustin
Fine cut 20g cold role mild steel
- Attachments
- A look from the side
- image.jpg (40.33 KiB) Viewed 1257 times
- A look at the edge
- image.jpg (34.44 KiB) Viewed 1257 times
- The whole thing
- image.jpg (146.65 KiB) Viewed 1257 times
- The whole thing
Re: Fine cut 20g cold role mild steel
Well...you need to get your height control working...if the torch height is incorrect expect dross, warpage, and a very wide cut kerf. Proper cut height is critical for all plasma cuts....even more so when the material is very thin.
I would help you out with it but you do not indicate what type of machine and height control you are using....
I also have some updated cut charts that allow for slower cut speeds (under 150 inches per minute) that will work with your FineCut consumables. It is a .pdf file, so if you email me directly I can forward it to you....no way to post it on this site.
Jim Colt jim.colt@hypertherm.com
- swidick
jimcolt wrote:Well...you need to get your height control working...if the torch height is incorrect expect dross, warpage, and a very wide cut kerf. Proper cut height is critical for all plasma cuts....even more so when the material is very thin.
Hi Jim, I just sent you an email request for the updated chart.
Steel Cut
Hypertherm 45, Burntable 4x8, Air dryer
Draftsight, Sheetcam, Mach 3, 1953 Chevy COE Crew 4x4 Duramax 2500
