Plate Dogs
- JJsCustomDesigns
Re: Plate Dogs
What is it
PM me with details
PM me with details
- JJsCustomDesigns
Re: Plate Dogs
ohhh.... i gotcha. Ive never heard of that term. Thats a nice design.
Ive only ever seen em like this.
PM me with details
PM me with details
- tnbndr
Re: Plate Dogs
Do they work ok without teeth cut in the gripping portion?
Can you share the dxf file?
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
Re: Plate Dogs
It is just a personal opinion guys - I would not trust this plate dog in a VERTICAL lift to save my life because that could easily be what is at risk. I have used plate dogs for over 40 years and I have a nickname for them - bitch clamps. Because when you least want one like that not too, the bitch will come loose!
Take it for what it is worth guys.
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
Hypertherm 1250
Corel Draw X6
Mach3
Lots of ineptitude
Re: Plate Dogs
Bill, you are definitely speaking the truth!!!!!!
Re: Plate Dogs
They are not for lifting vertically. They are horizontal lift dogs. There is no way you could even use them vertically. You put one on each side of the plate and connect them with a chain.
- JJsCustomDesigns
Re: Plate Dogs
Looks like a few nice products to make a buck or 2 off of there.
jk jk
PM me with details
PM me with details
- tnbndr
Re: Plate Dogs
Now it makes sense why they don't have teeth.They are not for lifting vertically. They are horizontal lift dogs.
Re: Plate Dogs
For non verticle lifting using a pair of them then that design works very well. My head went to verticle when I saw the post.
plain ol Bill
Hypertherm 1250
Corel Draw X6
Mach3
Lots of ineptitude
Hypertherm 1250
Corel Draw X6
Mach3
Lots of ineptitude
Re: Plate Dogs
Hello all, first time posting. I recently acquired a cnc plasma/router table designed and built by another member here "Weldtutor". His loss my gain! Still busy learning, but I thought I would contribute to this thread.
Attached are images for a horizontal plate lifter that I drew up in Solidworks. I have not built a set yet, but they are similar to standard plate lifts. I have created dxf's but am unsure about civil litigation. I purposely limited the jaw opening to 3/8" material so that when used in pairs the load would not exceed 1000 lbs (4 X 8 sheet of 3/" mild steel).
Any thoughts or concerns......
Re: Plate Dogs
I have had a completely different experience. I have several different plate dogs that I regularly lift over 1000 lbs with. In 20 years, I have never had one slip. I use them for lifting 10 gauge wall panels, beams and tubing in the vertical position, full sheets of steel plate up to 1".plain ol Bill wrote:It is just a personal opinion guys - I would not trust this plate dog in a VERTICAL lift to save my life because that could easily be what is at risk. I have used plate dogs for over 40 years and I have a nickname for them - bitch clamps. Because when you least want one like that not too, the bitch will come loose!
Re: Plate Dogs
I've worked as a boilermaker fitter/welder for 38 years and have used my share of plate clamps, they can come loose if jared.Also if they aren't welded properly you could have problems.It's not worth the risk.Jim
Re: Plate Dogs
hemichargersrt8 that is some cool modeling software!
plain ol Bill
Hypertherm 1250
Corel Draw X6
Mach3
Lots of ineptitude
Hypertherm 1250
Corel Draw X6
Mach3
Lots of ineptitude
Re: Plate Dogs
Great pictures hemichargersrt8! There are so many good resources on this site to learn from.
