Hey guys / gals,
I'm contemplating cutting out some fire rings for resale but one issue I'm struggling with is the actual rolling of the metal in to a "ring" / circular form.
What gauge steel are you typically using?
What are you using to 'roll' the steel to produce the ring?
Homemade? Factory made? Price of the roller system?
I've spent a fair amount of time surfing the net and the metal rollers I'm seeing that would work are BIG bucks... Being a backyard kind of producer I don't want to drop a ton 'o money on a roller.
Just looking to see what people are doing in this area. Why re-invent the wheel...
Thanks all !!!
Copp3r / roger
Metal Roller - for fire rings, etc
- Copp3r
- tnbndr
Re: Metal Roller - for fire rings, etc
I make my fire rings out of 12 gauge and roll them in a used Pexto 391 that I picked up off of ebay years ago for around $800. It is only rated for 16 gauge but that is at full 36" length. My rings are only 12" so it will roll the 12 gauge although it complains some. I powered my roller with a geared motor so that I can roll rings alone and control the metal. I think turning by hand would require both hands and someone else to control the metal.
Only other option is to not go round, there are some hexagonal ones shown on this forum.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
- superoverenginered
I help part time with a small company that makes their firerings out of 11ga and I cut 2 pc and bend them with a small shop press so they are 6 sided. Most people really like them instead of round...you can easily take them apart and ship them.
Why make one when you can make 2
5x10 Arclight Dynamics plasma table
powermax 65
Concrete Printer with dewalt router
Miller mig/tig
powermax 65
Miller mig/tig
I do mine in an octagon and have a 1000.00 4' brake. or u can do the oct. and cut a line where u want to bend and it will bend easy.
Just bought a vintage Niagara 3"x36" pinch roller. Rated at 14 gauge, handles 14" of 12 gauge, no probs. Best of all, Made in America by real Americans with real American steel, back in the 60's.
K D Metal Werks
PlasmaCam DHC2
Hypertherm Power Max 45
Hobart Handler 190 Mig
Niagara 3"x 36" Slip Roll 14ga
Driess/ Krumph 4' box & pan brake 16ga
Hossfeld #2 Bender Ridgid 700 threader
Pexto 137-1 16ga. Stomp Shear
MADE IN USA
PlasmaCam DHC2
MADE IN USA
Harbor freight sells a roller that works well for flat and round steel.
Pay a larger job shop that has one $20 bucks and add to cost!
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
Plenty of welders
PowerMax 45
Lots of other toys
