plasma firing issue
plasma firing issue
I have an old TM1. hypertherm 600. no AVHC. recently it has started this. it will go to the first pierce, fire, then go out. I back it up try again. sometimes it fires and goes. sometimes I have to back up a couple times. once I get through that initial problem its all good after that. Any ideas? Thanks in advance
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Re: plasma firing issue
check the relay inside the start box, the one that clicks when the torch fires. I had the same problem, it would fire sometimes and sometimes not. sometimes it would be cutting fine then the torch would lose fire. I called torchmate and they wanted $200 for the box...i got the number off the relay and ordered it for $7 online from an elecronics supplier. no problems since
