I am having an issue getting a good coat of paint on the butterfly chair that I just made my wife. I hit the chair with a DA and went over the surface to clean the dust off. Now, thick or thin it seems that there is some sort of rust coming up through the paint.
I didn't remove all the mill scale, but again, I DA'd it to scuff it. I am using a Glidden Exterior paint. I have hand brushed it on, and it only shows up in some areas and not others.
Help on this would be much appreciated.
Surface Rust?
Surface Rust?
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
Plenty of welders
PowerMax 45
Lots of other toys
Re: Surface Rust?
Not sure what is causing the problem you are having but I can tell you that 90% of a good paint job is surface prep. You probably won't get a good, long lasting paint job if you have mill scale. You might could clean it with muratic acid or ideally have it sandblasted.
Danny
Danny
- tnbndr
Re: Surface Rust?
Sandblasting would be best and then use a Rustoleum primer. I use Rustoleum primer for rusted metal even on metal that I think is rust free.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
Re: Surface Rust?
Well it's looking like I might be paying out for this one. To get it stripped and done right the second time...
Thanks for the comments.
David Finch CWI
Plenty of welders
PowerMax 45
Lots of other toys
Plenty of welders
PowerMax 45
Lots of other toys
