Part numbers for TM1 motor pulleys
any idea what the grainger part number's are for the motor pully's on the TM1? or the specs?
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
- Gamelord
- 4.5 Star Member
Re: part numbers
Get with Torchmate directly and they can get you taken care of. What parts do you need? I may have some laying around that I don't use anymore. I upgraded to the geared transmission drives and got rid of the belts.
Torchmate CAD
Torchmate CAD
Re: part numbers
looking for the two pully's on top and the belt. I am not a big fan of torchmate service right now. I can get the same parts quicker and the RIGHT parts from grainger. I had a list at one time but cannot find itGamelord wrote:Get with Torchmate directly and they can get you taken care of. What parts do you need? I may have some laying around that I don't use anymore. I upgraded to the geared transmission drives and got rid of the belts.
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Re: part numbers
anyone?
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Re: part numbers
It's hard to tell for sure but that's probably a standard MXL series (.08" pitch)
between comparing tooth count and od with various pulley specs, it should be easy to pick the right one
you can determine the pitch by measuring the belt, for MXL ten teeth would measure .8"
then you just have to match the belt width and bore, beyond that you don't really have to use components with that same pitch (if it's not MXL you could retrofit with all MXL components), as long as the tooth ratio is the same
sdp-si.com has a nice searchable catalog
