Ohmic Touch & Go Post Processor Question
- The-Meerkat
Looking for the best post processor for a ohmic sensor touch & go setup used with SheetCam & Mach3. What post processor do use?
Scott Meer
Re: Ohmic Touch & Go Post Processor Question
here is a generic post I modified for use with a probe. you also need to enable the porbe input in Mach and select the pin you have the probe attached to for it to work. Some post that are set up for some electronics will need to be used due to their configuration. The main change from a floating head switch to probe is the change from G28 to G31 command in the post as shown in the attached image of the post I sent.
- The-Meerkat
Acourtjester, thanks so much. The weekend is here so I’ll load your post up tomorrow and give it a whirl.
Scott Meer
