I recently rebuilt a salvaged CandCNC table with rack and pinion drive. Build my own controller based on Mach 3 with ESS and THC-2 from CNC4PC.
What do you all think about running some sort of lubrication on the gear rack for a system like this and if using lube, what do you recommend?
Thanks all!!
lubricating rack and pinion or not?
- Tristar500
5X7, 6x11 plasma own design
Mach3,4 SheetCam, CorelDRAW 2020 Inkscape .0.92
Homebuilt 3 axis mill
Homebuilt 5 axis mill
PrimeWeld cut 60
Hypertherm 350
Miller Symchrowave 250 DX
Several mig welders
You are only as old as the woman you feel.
PrimeWeld cut 60
Hypertherm 350
Several mig welders
Re: lubricating rack and pinion or not?
I have a rack on one of my axis and do run some lube on the rack, not a lot just enough for smooth operations. Watch for dusk built up, not much does happen as the rack is high away from the action.
I run this, it makes a huge difference. Almost total elimination of gear mesh noise.
Dry lube for sure or metallic dust will build up on the rack and it will counterproductive.
- tinspark
ditto on the dry lube. i use dry lube on my system
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Hypertherm 45XP-
Is this a WD-40 stuff considered a dry lube?bLouChipBlacksmith wrote: ↑Sat Dec 02, 2023 10:14 pm I run this, it makes a huge difference. Almost total elimination of gear mesh noise.
Are y’all talking about stuff more like a graphite lube that is painted on and dries in the air. We used that on the deck tubes that slide up/down in/out for car haulers. Ironically the stuff was called slide or something like that.
EDIT:
Stuff was called EZ Slide. I see another brand called Slip.
- tinspark
Regular WD-40 is not a dry lube, but they do make a dry lube (see below) This is the stuff that a lot of guys use around here. a spray can is easy to use and should last a while. I really only use the dry lube for my CNC machine for the gear rack and exposed bearings on my CNC machine etc. But keep a gallon of regular WD-40 around to lube all sorts of stuff around the shop and home.. Dry is harder to find, so I always just order online..
Here is an Amazon link . $8
Doug,
Hypertherm 45XP-
Hypertherm 45XP-
- Tristar500
I ordered the WD dry.
Thanks all!!
Thanks all!!
PrimeWeld cut 60
Hypertherm 350
Several mig welders
PrimeWeld cut 60
Hypertherm 350
Several mig welders
Ok thanks guys. That PTFE is what scares me :/
