Trial Cut Path
Trial Cut Path
Post by tnbndr »
Sorry, did a search and found nothing, but probably using the wrong search words.
Is there a way to easily run the torch through the g-code generated without the torch firing? Just want to watch the cut path and moves.
TIA
Re: Trial Cut Path
I assume you have DTHC is so you can click off that function on the program page of Mach, but you may also need to short the ARC OK signal so it thinks the torch is on.
_Ogre
Re: Trial Cut Path
Post by _Ogre »
turn the plasma and thc off
often after tooling change, i'll forget to turn on the plasma and it traces
exapprentice
Re: Trial Cut Path
Post by exapprentice »
I am sure on the Arclight web site there is a video showing the set up and what to do if you want to "Dry Run" or "Trial Cut Path" of a file with out the torch firing,
In fact I am positive :roll: there is a video of this on their site, might be of some help :?:
Best Regards to all
Exapprentice :D
(Pete)
WyoGreen
Re: Trial Cut Path
Post by WyoGreen »
I often turn off the plasma cutter when I want to dry run a g-code file in Mach3. Sometimes you have to hit run after each touch-off, sometimes you have to hit the fire torch button after each touch-off.
Router
Laser
Brand X
Re: Trial Cut Path
Post by Brand X »
It use to be real easy before I upgraded to the last Candcnc download. Plasma off, and hit run,then fire button . Now I have to flip the Arc good switch I put in to the system to get it to move. (Also plasma off.) Not a big deal, but it still will run though all it's code that way..The vid of the Arclight does not work the way mine does now..
Re: Trial Cut Path
Post by tnbndr »
Thanks All.
Watched the video and will try soon.
Return to “Mach3 & Mach4 CNC”
